New water pump instal leaking - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2019, 11:22 AM
Hi,
I put in a new water pump on a 2003 Durango 5.9L using a Fel pro gasket.
The gasket is meant to be installed dry and clean, so that's what I did. I usually put some other sealer along with a gasket and don't have any leakes. Didn't use sealer this time and it didn't work out so well.
Right now the pump is very easy to get to, so I was thinking to give it another try with no supplemental sealer, or should I just run a bead of silicon on both mating surfaces along with the gasket.
The old pump did not have any other sealer.
Thanks.
Old 05-13-2019, 11:44 AM
silver74vette's Avatar
I rub a very thin layer of silicone over the whole gasket, don't want a bead squeezing out inside the passage and coming loose in the engine.
Old 05-13-2019, 11:46 AM
Yes, that's what I meant to say. Bead is not the right word.
Thanks.
Old 05-13-2019, 01:57 PM
Don’t use silicone sealer on anything. That is terrible sealer, and it will get into your cooling system. The excess silicone sealer does not dissolve.
Use a small amount of Permatex “The Right Stuff”. It seals between the gasket and accessory.
Old 05-13-2019, 02:15 PM
The Right Stuff is my favorite, it's all I use.
I have a pretty strong feeling I forgot thread sealer on a bolt or 2. It's been about a year since I put the engine together, so I'm not sure, but that's what I'll check first.
Thanks.
Old 05-13-2019, 02:20 PM
55 Tony's Avatar
Edelbrock Gasaginch if that's how you spell it works well.
Young enough to learn ... too old to remember.
Old 05-14-2019, 11:34 AM
Originally Posted by Infinite Monkeys View Post
Hi,
Thanks.
No sealer works great at the factory when the machines surfaces are fresh, new, straight, and super clean. After a few years in the field with some heat cycling if not over heating and the manufacturing stresses workout usually adding some contour to the machined surfaces, pile on some grit and grime and suddenly the poor old gasket is having a hard time sealing this up. So a little ozzey compound can help prevent going back in to fix it again.
Another thing to investigate is whether the mounting holes are blind or not. If not blind or cracks at the base, or drilled through when they shouldn't have been on blind holes or local casting cracks exist in the threaded area coolant can weep around the threads of the fasteners. Certainly if the threaded holes are not blind some thread sealer is needed, if not a little sealer can still cover these other contingencies.
Bogie
The Following User Says Thank You to BogiesAnnex1 For This Useful Post:
Infinite Monkeys (05-14-2019)
Old 05-17-2019, 05:42 PM
Bogie
I always learn something new when I post on this site.
I've been through dozens of vehicles in the last 15- 20 years and did a lot of work on most of them. However I am still learning. This time I missed how badly the timing cover to engine water passage was pitted and that is where the leak was, not at the water pump as I had first thought. The rest of the cover looks good and there were no leaks from anywhere else.
Now I'll know what to look for next time.
Thanks again.
ID:	443381   Click image for larger version
454 block leaking around water pump or block area Riley Engine 16 07-04-2012 09:46 PM
65 Mustang (1975 302) overheating promblem. Water pump question Robert08 Engine 4 06-22-2008 11:45 AM
Water pump inlet extension steve392 Engine 4 05-05-2008 02:31 PM
Water pump leaking? Guy Hiltz Engine 2 05-22-2006 10:16 AM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
