Newbie paint Q: how smooth does primer need to be? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2018, 08:12 AM
Hey all, so I'm new to painting car panels, and have a few cars underway that I intend to do with a buddy who has extensive(decades)experience with spray paint, but none with an actual car. I'm doing most of the prep work, and he'll be shooting, as he's got much better hand control. So my question: how smooth do I need to get the primer before shooting base coat? I have completely straight metal, primer on, and have done numerous passes of primer/wet sand to get any imperfections out. what I want to know is this: how critical is the smoothness of the primer in the end product? there are no chips/dings/etc, but the final pass of primer is still straight out of the gun, so it's rough feeling. do i need to thoroughly block the entire car before base coat, or will 2 coats of base "cover" the natural roughness of the primer? thanks for the help!!-RJ
Old 06-18-2018, 09:31 AM
It depends on how good a job you want. But the primer is generally smoothed out flat in most any situation where a nice job is the end result wanted.
And in fact, perfect flat IS the super basic goal of those who want a nice job. Think about it, you are in complete control, you have the afternoon, the music playing in the shop/garage, a cold drink, and you make it perfectly flat because it's easy, just get it done and that makes the whole job much better.
You don't have to "block" it, sanding it with finer paper with a foam block or nothing at all isn't going to cut waves or anything, as long as you are doing it reasonably correct. The "flattening" done by blocking is done with coarser paper, it is CUTTING it flat. By the time you get ready for paint, just simply "sanding" you aren't using that coarse of paper and you are only removing the texture so blocking isn't needed.
It's so funny, when I think of how much sanding I did "back in the day" on lacquer paint jobs on show winners, OMG. We could sand EVERY SINGLE SQUARE INCH of the surface to PERFECTION. We are talking ZERO texture, not even a single little spec a 1/16" would remain there un-sanded. EVERY SINGLE SPECK of the surface would be the non glossy sanded surface, EVERY SINGLE SPECK of the surface. Ok, here is the funny part for those who didn't do this back then, that is not only how we started to paint, with the primer sanded like that. But after every four or five coats of paint we did it again! And would typically apply 15 coats. So we would do that FULL SANDING of EVERY SINGLE SPECK of the surface after the first five coats, then after the tenth coat and then at the end where it would be sanded perfectly smooth and then polish it to a mirror finish! And I am talking on the cars I did, in the door jambs, firewall, dash board, EVERY SINGLE SPECK of the paint that would be seen would be sanded like this!
Yes, I had no finger prints in those days.
Old 06-18-2018, 09:34 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
What we look for in shooting a car is for the paint to lay down what we call "gun done". That is the paint lays out wet and slick with no need to sand other than maybe go over it a de-nib if some trash snuck in. So you may have to reduce the primer about 5 to 10 percent and work on gun adjustment until you get there from here.
https://www.southernpolyurethanes.co...-gun-adjusting
https://www.southernpolyurethanes.co...sting-your-gun
Have fun..
Sam
Old 06-18-2018, 01:32 PM
Imho, the primer needs to be sanded for adhesion purposes. The base needs "tooth" to stick to unless it is a wet on wet type of primer/sealer application within specific time windows such as an epoxy or 2k sealer. Most paints tech sheets are online so I would look up their prep recommends. Usually 400g minimum for solid color base and 500-600g for metallic bases. No way would I put base down over a cured primer without prep. Just asking for adhesion issues.
Old 06-18-2018, 07:10 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
Any unsanded texture not only shows right through basecoat but results in poor adhesion.
Old 06-18-2018, 08:03 PM
I have been prepping cars for a while just throw on three coats of prime and let it dry and then after that block it put some guide coat down you can start with 320 and work your way up I cut all the orange peel out with the 320 then work up to 600 grit to get out all the course scratches
Old 06-20-2018, 11:36 AM
Great info, thanks you guys! Last question for now: how fine should I go on the primer before we start shooting base coat? My instinct says that something in the 1200-2000 grit range would be sufficient, but that's just me guessing. FWIW, I am not out for a $15k looking paint job. I don't want a total halfass garbage job, but I am not intending to put 100+ man hours into a paint job. A nice, solid job that looks good at a quick glance is fine with me. Thanks!
Old 06-20-2018, 12:13 PM
idrivejunk's Avatar
Grand Prix User
600 wet or 400 dry. 1200-2000 is used prior to polishing and is much too fine.
The Following User Says Thank You to idrivejunk For This Useful Post:
John long (06-20-2018)
Old 06-23-2018, 09:05 PM
Depending on the color, I usually go 400 to 800. 400 for solid color (white, black, red, etc) 600-800 for metalics, and BC pearls. 800 for light metalics, and BC pearls. for 3 stage pearls I've found 400-600 to be sufficient, as the base color will fill the sanding prior to the pearl coat.
I've also been known (if out of finer paper) to spray a coat or two of 895, or Base Fix, (what amounts to clear base) before applying color, especially light metallic such as silver, and light blue.
Also, when out of "scuffin' stuff" I've been known to use 800-2000 to prep for blend. Works quite well.
As does Comet, or Ajax.
anti stone chip smooth primer on early fenders ,want nice finish carfan Body - Exterior 13 06-16-2012 11:31 AM
anyway to get primer fillers to spray smooth proge Body - Exterior 3 05-18-2009 12:53 PM
intake manifold i plan to sell, should i polish it, or smooth it for paint lowROLLERchevy Hotrodding Basics 4 02-10-2006 11:40 AM
what is best to smooth body to paint wiretwister Body - Exterior 3 12-24-2005 08:17 AM
Newbie question-primer bluebu Body - Exterior 16 03-24-2005 10:34 AM
