Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - No gasoline at the carb
Old 12-01-2018, 04:16 PM
poncho62's Avatar
poncho62 poncho62 is offline
Last journal entry: 77 Ford
Wiki Edits: 5
What I would do is, take the connection from the tank at the input of the pump off. Take a hose the right size and put it from there into a 1 gallon gas can with some gas in it. Crank it over. If it draws gas from there, the problem is from the pump back. If not, the pump is likely no good. It is an engine mounted pump, right?
The Following User Says Thank You to poncho62 For This Useful Post:
gatoraid (12-01-2018)
