No gasoline at the carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2018, 02:12 PM
I have replaced fuel tank, sending unit, fuel line, return fuel line, all new rubber fuel lines, fuel pump, fuel filter and new carb. I have cranked the motor for over 1 minute and still no gas. do I need to keep turning the motor over or something else?
Old 12-01-2018, 02:25 PM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
I would suspect the pump is bad....or you have a leak and its just sucking air.
What car, engine etc?
The Following User Says Thank You to poncho62 For This Useful Post:
gatoraid (12-01-2018)
Old 12-01-2018, 02:36 PM
gatoraid
350 chevy 4bbl 1984 K5 blazer. everything is new, just replaced and installed today. there is gas in the tank. anything need to be primed?
Old 12-01-2018, 04:16 PM
poncho62's Avatar
Wiki Edits: 5
What I would do is, take the connection from the tank at the input of the pump off. Take a hose the right size and put it from there into a 1 gallon gas can with some gas in it. Crank it over. If it draws gas from there, the problem is from the pump back. If not, the pump is likely no good. It is an engine mounted pump, right?
Old 12-01-2018, 04:29 PM
39 master's Avatar
Engine mounted fuel pump...was the pushrod put back in? Was the pushrod holding bolt loosened?
The Following User Says Thank You to 39 master For This Useful Post:
Old 12-01-2018, 07:59 PM
Thanks for the info. I'll try the gas can and hose trick.
Old 12-02-2018, 07:38 AM
Are you using a mechanical pump on the side of the block and also when you installed a new sending unit did it have an electric fuel pump on the sending unit? In my experience you can't run a mechanical fuel pump and have it pull fuel through an electric fuel pump on the fuel tank and it not be hooked up and if you were to have it hooked up depending on the fuel pressure you would have to have a regulator to keep the pressure correct.
On all my s10 v8 swaps I had to take out the in tank pump so my mechanical pump would be able to pull fuel. The first time I did this many years ago I had everything hooked up and turned and turned over and did not get any fuel. I had to have the tank dropped and the electric fuel pump removed then problem solved. Just something to check.
The Following User Says Thank You to eric32 For This Useful Post:
gatoraid (12-02-2018)
Old 12-02-2018, 07:55 AM
55 Tony's Avatar
In addition, do your battery a favor and pour a little gas down the carb before the next try. Might take a couple starts and stalls till it's pumping fuel.
The Following 2 Users Say Thank You to 55 Tony For This Useful Post:
gatoraid (12-02-2018), joe_padavano (12-02-2018)
Old 12-02-2018, 07:59 AM
Old(s) Fart
Last wiki edit: Wheelbase database
You completely replaced everything in the fuel system. It takes time for the pump to suck fuel from the tank and fill the float bowl in the carb. The easy thing to do is to fill the carb through the bowl vents. I use a turkey baster or similar tool.
The Following 2 Users Say Thank You to joe_padavano For This Useful Post:
adantessr (12-17-2018), gatoraid (12-02-2018)
Old 12-02-2018, 09:30 AM
meborder's Avatar
Is this a roller cam motor, I hope?
If not, you likely have bigger problems by now.
The Following 3 Users Say Thank You to meborder For This Useful Post:
adantessr (12-17-2018), gatoraid (12-02-2018), techinspector1 (12-03-2018)
Old 12-05-2018, 04:57 PM
potvinguy's Avatar
The tank has a vent, I assume?
The Following User Says Thank You to potvinguy For This Useful Post:
gatoraid (12-06-2018)
SBC 5.7l 350 TBI 1987 K5 No CEL, no idle, no power/seems to misfire SBC350 TBI 87' Modern Electronic Engines 9 06-27-2018 12:18 PM
"No shirt, No shoes, No service" 46stude Hotrodders' Lounge 8 11-30-2004 06:32 PM
gasoline in oil pan ffcagle34 Engine 3 02-20-2003 11:53 AM
Converter, diesel vs gasoline Norwegian Transmission - Rearend 1 10-29-2002 01:24 AM
a question about gasoline and 70's cars ruger Hotrodders' Lounge 5 09-24-2002 09:39 PM
