No power to starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2017, 05:02 PM
No power to starter
Got the 548 Chevy installed in the 70 vette. Battery installed and all and have the big starter wire hooked to the starter . but there is no power to the big wire. If u put my tester on the battery it lights up. its not hot at the starter though..
Old 12-19-2017, 06:38 PM
29fordcoupe's Avatar
Last journal entry: Working suspension now.
The big wire from the battery to the starter should be a single wire going straight there. Could it have been severed during the engine swap?
Trace the length of the wire. Make sure the battery terminals are clean.
Old 12-19-2017, 07:10 PM
39 master's Avatar
Starter power
Don't forget the ground wire(s) too.
The Following User Says Thank You to 39 master For This Useful Post:
29fordcoupe (12-19-2017)
Old 12-19-2017, 08:13 PM
Yes thats prob it. Right now the battery has a ground to the chassis but there is not one from the motor to the chassis . will get a ground strap or two
Old 05-02-2018, 04:41 PM
ok so i just got back to this project
grounds and power hooked up, checked power at starter with test light
go to jump the starter wires and starter clicks over and just stops
once this happens no longer have power going to the power stud on the starter
then to get power back to the start i unhook the battery cable and hook it back up i have power to the starter again
Old 05-02-2018, 05:56 PM
ericnova72's Avatar
More for Less Racer
Still either a ground or a connectivity issue. Resistance goes sky-high as soon as you energize the circuit and kills the connection.
Corvette being fiberglass needs grounds to everything. Battery to motor, battery to frame, frame to body/underdash ground, body/underdash ground to motor(this was typically back of cylinder head to firewall mounted ground junction). Clean connection points on everything including battery and terminals
Also starter nose cone contact to block, paint on block at starter mount can be a problem, so check that.
Electricity needs a full loop everywhere it goes...it not only has to go from battery positive to switch, but battery positive to component, and then back from switch or component to battery ground. When it can't make the complete loop, it won't operate.
Old 05-02-2018, 09:08 PM
ogre's Avatar
the 'Duracell Project'
main ground cable should go from battery to the motor as the starter is the only thing that uses the 100% battery draw
then ground everything else off the motor
and check what ericnova72 said about paint between the starter and block
Old 05-02-2018, 11:07 PM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
If I had this vet i would have the ground cable the same size as the + . I would also have it tied down on the bell housing / flywheel dust cover
pep
Old 05-04-2018, 06:02 AM
thanks for all the insight and advice, do have a cable that is the same size as the +, have to pick up a couple cable ends and then will attach it from the battery to the motor and give it another go. will report back
Doug
ID:	423433   Click image for larger version
ID:	423441   Click image for larger version
ID:	423449   Click image for larger version
Old 05-04-2018, 07:22 AM
rip-tide's Avatar
What is the condition of the battery is it new, full charge? You will be better off having the motor ground from the battery. I just asked the question about the battery cause the description highlighted that is odd.
Unless the starter sol is hanging, what is the condition of the starter?
The sol is nothing more than a relay. Big current that is required to turn over a motor. Can and will burn the contacts, causing pitting and carbon, that causes resistance, that causes, a voltage and current drop to the starter motor.
Sometimes one hears a click, click, click from the sol, low battery. But if is clicks once then nothing there is a good chance the sol has bad contacts and should be checked or replaced.
Here's hoping the starter is easily accessible ...
Cheers,
pep
Old 05-04-2018, 07:29 AM
couple things, starter is a new mini starter, went to advance a couple weeks back and had them check it to see if it is good and it worked perfect on their tester. the battery is newer and it is fully charged with battery charger
Old 05-04-2018, 07:53 PM
rip-tide's Avatar
Ok i thought you were talking OME part, they are bulky but work long time.
I'm not a fan of these mini starters, read many post where folks have problems.
I'm stepping out for the reason mentioned above.
pep
chevy lumina getting no power to starter or spark. One to Remember Electrical 13 07-09-2015 12:19 AM
starter clicks once then loses all power. Axl900 Electrical 10 01-30-2013 08:12 AM
No power to starter HBrown Electrical 14 12-09-2012 07:10 PM
77 Buick Wagon - starter wires?/no power roadlet_411 Electrical 3 07-23-2010 09:32 PM
No battery power after starter replaced Rosewood Electrical 7 07-02-2010 11:02 PM
