No spark - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2018, 10:37 AM
No spark
I have a SBC 400. I discovered I have no spark. I checked the canister coil and I get primary reading of 1.8 ohms; secondary reading if 9,500 ohms. Specs for the Mallory coil for secondary is 10,800 ohms. Is the coil bad?
Old 07-12-2018, 12:38 PM
Make life simpler, disconnect the primary coil wiring. Then take the secondary high voltage wire and position it close to ground so you can see a spark if there is one. Then jumper the + side to 12 volts and jumper the - side to ground for second or two then disconnect it.
The question is; did you get a spark or not? No spark = bad coil, if there is a spark the problem is somewhere else.
Bogie
The Following 2 Users Say Thank You to BogiesAnnex1 For This Useful Post:
36 sedan (07-12-2018), BillPac (07-12-2018)
Chevy 350 No longer cranking and no spark Jackyl666 Engine 1 10-26-2008 04:13 PM
blazer has spark at coil and gas no spark at plugs ricksautorestoration Engine 29 02-15-2007 08:30 AM
help me PLEASE! no spark, no power, dieseling byrdta76 Engine 4 06-23-2006 11:44 AM
help me PLEASE! no spark, no power, dieseling byrdta76 Engine 3 06-22-2006 02:48 AM
No Spark, No Start Canadian Charlie Electrical 28 03-29-2005 04:36 AM
