OD 5 speed to a 67 ford F150 6 CYL - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2008, 04:10 PM
Has anyone done this swap, truck now has a granny low 4 speed, any ideas will help. Thanks.
Old 03-23-2008, 10:53 AM
jalopy45's Avatar
If you're talking about using a t-5 it's an easy great swap to reduce the rpm's and better fuel economy., Go to the www.inliners.org website and search around the drivetrain forum and you should find all the info you need.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 03-23-2008, 03:01 PM
sharpe427's Avatar
Or if you don't like the prices, try a 3 spd + overdrive Ford unit. They used them a lot in the late 70's early 80's to get better fuel economy. It is a toploader case with the 3-4 lever inverted so Ford only changed 1 gear to get you a .8 overdrive (20% reduction). It does have a pretty wide 2-3 shift though. They are relatively plentiful and cheap and will be a very easy bolt in swap. Used in trucks, Granadas and Mavericks mostly, it seems. If you go junkyard shopping, look for a toploader with 1 shift lever on the trans pointing down instead of up and you found your boy. All the usual toploader bits work (incl. overhaul parts).
Ford Flathead Six Speed Equipment DJD Engine 3 12-14-2009 07:16 PM
floor shift big truck ZF ford 5 speed Footstomper Transmission - Rearend 8 01-27-2008 09:21 PM
Ford 4 speed identification 29guy Transmission - Rearend 1 12-24-2007 08:33 PM
1992 ford f150. have cam problems big time cgreene Engine 2 05-02-2003 03:27 PM
84 Ford F150 aleblanc Engine 2 11-06-2002 05:01 AM
