Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - OEM or Stainless Steel Fuel Lines?
Old 03-11-2008, 05:32 PM
64 Impala SS 96 64 Impala SS 96 is offline
Originally Posted by cope
i like 3/8 stainless fuel lines dont have to worry about them rusting out.
i wouldent remove the control arm i would just get it off any way i could than route the new one around it not trew the control arm.
i would think the other one sould just slide out of the frame use some brake cleaner to clean it up than spray some wd40 in there and try and slide it out
Ok, yea, I figure some can of brake cleaner and some elbow grease would be all I need on the middle line however it does seem to have some seals that go around the line.... that are pretty much shot so I will need something in there....
And I will check into re-routing the fuel line in the front. I honestly would rather do it original.... if thats the way it was out of the box, I'd rather keep it that way.
