Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - OEM or Stainless Steel Fuel Lines?
Old 03-12-2008, 02:55 PM
73oldsman's Avatar
73oldsman 73oldsman is offline
I replaced the old corroded ones on my Olds with stainless steel ones a while back. After seeing how much corrosion was in those old fuel lines I think stainless is the only way to go. It can be a bear to get the old lines out so be ready to get dirty! Also it will help if you have access to a local car shops lift to raise the car up enough to work the new lines in from underneath. Of course, that would be a real luxury to most of us 1 car garage mechanics! Good Luck!
