Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - OEM or Stainless Steel Fuel Lines?
Old 03-13-2008, 07:52 PM
73oldsman's Avatar
73oldsman 73oldsman is offline
The lift I referred to was just to give more heigth to lift the car up to work the lines out or back into the car. I replaced the lines myself on my Olds! I can't even imagine how much a shop would charge to replace the fuel lines! Besides, then you would miss out on being able to say "I did it myself". As far as the frame clip goes, is there not an access hole near the clip that you can get at it with a screwdriver and pry and work the clip up while working the line out?
