Hot Rod Forum : Hotrodders Bulletin Board (https://www.hotrodders.com/forum/)
-   Suspension - Brakes - Steering (https://www.hotrodders.com/forum/suspension-brakes-steering/)
-   -   Is an offset rear end normal ? (https://www.hotrodders.com/forum/offset-rear-end-normal-522809.html)
Skooch62 09-10-2019 11:06 AM
My new 31 Model A Tudor has a Ford 9Ē rear but I noticed itís not centered between the 2 tires. Itís offset about 2 inches. Is this unusual ,is there a reason , or did previous owner mess up ?
BigMo 09-10-2019 11:10 AM
Its not a show stopper, prob got the rear with an existing offset and then installed it with the hubs/axle flanges lined up equal under the car.
Sent from my SM-G900V using Tapatalk
delawarebill 09-10-2019 11:14 AM
gonna say yes also
i don't recall seeing a 8" or 9" with 3rd member in the middle. my Tbucket with 8" rear was off set and had no problems
BigMo 09-10-2019 11:23 AM
Exactly....nothing came stock centered. When i build one custom i will center the pinion w the car center line, cut axle tubes/weld bearing ends, and get axles made to fit....like on my Coupe and many other cars i have built for folkshttps://uploads.tapatalk-cdn.com/201...88aaa7c13f.jpghttps://uploads.tapatalk-cdn.com/201...d9756d3177.jpg
timothale 09-11-2019 06:08 AM
center pumpkin
If the pumpkin is centered then your drive shaft will be offset. When I first looked at the new in 03 Ford GT the rear center section is to the rear of the perpendicular center line of the wheels. the rear half-shafts just didn't look right. When building new floor pans you have to check for actual drive shaft clearance not just center the hump in the floor.
timothale 09-11-2019 06:13 AM
quick change rear
when using a quick change rear with a humped model A or T spring it looks best to center the rear and have the drive shaft off set. I haven't checked out the Jag XJ Irs but I think the pumpkin is centered, I've got one on a pallet ready for a T bucket.
