Is an offset rear end normal ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2019, 11:06 AM
My new 31 Model A Tudor has a Ford 9Ē rear but I noticed itís not centered between the 2 tires. Itís offset about 2 inches. Is this unusual ,is there a reason , or did previous owner mess up ?
Old 09-10-2019, 11:10 AM
BigMo's Avatar
Its not a show stopper, prob got the rear with an existing offset and then installed it with the hubs/axle flanges lined up equal under the car.
Sent from my SM-G900V using Tapatalk
The Following User Says Thank You to BigMo For This Useful Post:
Skooch62 (09-10-2019)
Old 09-10-2019, 11:14 AM
delawarebill's Avatar
gonna say yes also
i don't recall seeing a 8" or 9" with 3rd member in the middle. my Tbucket with 8" rear was off set and had no problems
The Following User Says Thank You to delawarebill For This Useful Post:
Old 09-10-2019, 11:23 AM
BigMo's Avatar
Exactly....nothing came stock centered. When i build one custom i will center the pinion w the car center line, cut axle tubes/weld bearing ends, and get axles made to fit....like on my Coupe and many other cars i have built for folks
Old 09-11-2019, 06:08 AM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
center pumpkin
If the pumpkin is centered then your drive shaft will be offset. When I first looked at the new in 03 Ford GT the rear center section is to the rear of the perpendicular center line of the wheels. the rear half-shafts just didn't look right. When building new floor pans you have to check for actual drive shaft clearance not just center the hump in the floor.
Old 09-11-2019, 06:13 AM
Wiki Edits: 27
quick change rear
when using a quick change rear with a humped model A or T spring it looks best to center the rear and have the drive shaft off set. I haven't checked out the Jag XJ Irs but I think the pumpkin is centered, I've got one on a pallet ready for a T bucket.
