Oil change : refill ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2019, 10:27 AM
Hey guys trying to change my oil in my car but cant find anything that screams "add oil here!" Its a non original 305 with aftermarket edelbrock valve covers. I read you can add through dipstick but I dont have a funnel small enough. I also heard it can go right into the valve covers but before I add anything I want to clarify. Anybody got any ideas? I'll post a few pics of engine as well.
ID:	442547   Click image for larger version
Old 04-21-2019, 10:41 AM
Pour oil into the valve cover oil fill / breather hole.
Old 04-21-2019, 10:44 AM
That's okay to do? Does it matter which valve cover?
Old 04-21-2019, 11:05 AM
Bob37pont's Avatar
Curmudgeon at Large
Yes, that is where the oil gets added, either one is fine.
While you're at it I'll assume you are also changing the oil filter.
Clean the surface the oil filter seal contacts.
Be sure to smear some clean oil on the rubber seal on top of the filter, and fill the filter with oil before you screw it on. Only tighten the oil filter 3/4 of a turn after the filter is hand snugged.
Old 04-21-2019, 11:09 AM
Okay awesome and I actually did all that before I was getting ready to add oil. Thanks for the heads up info! Would 5 quarts be enough? A little less since I added a bit to the filter.
Old 04-21-2019, 11:25 AM
ericnova72's Avatar
More for Less Racer
With a stock oil pan, 4.5 to 5 quarts will be correct depending on the size of the oil filter.
Old 04-21-2019, 11:27 AM
The oil filter is a fram ph30 seems a bit small to me but fit perfectly fine.
Old 04-22-2019, 03:49 AM
75gmck25's Avatar
Last journal entry: Engine replacement
For my 350 I usually use a Delco PF1218 or Purolator L34631. They are always stocked at the parts store, and available with the typical weekly oil special pricing for 5 quarts of oil and a filter.
Bruce
Old 04-22-2019, 05:43 AM
Bruce
I used a Castrol high mileage oil. I will definitely consider other better oils and filters
Old 04-22-2019, 06:05 AM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
Not a thing wrong with Castrol, the will keep a motor very clean. Of course with regular changes, on the other hand, fram is well known crap. A roll of toilet paper would give better results.
Pep
Old 04-22-2019, 06:06 AM
delawarebill's Avatar
oil
if u want to add some oil to the filter before install that's fine, but just add the rest of the 5 qts into the valve cover. on fire up don't rev the engine, allow to pump oil first for a minute.
Old 04-22-2019, 06:19 AM
Pep
That's what I've been hearing. On the next change I'll switch it to another brand!
Strange Oil Change Florida Camaro Engine 3 05-21-2014 01:24 PM
Oil pressure in the 1-2 pd range? Please help... LittleC3Ttop Engine 15 02-21-2011 11:14 AM
No oil pressure after oil change. 69ChevelleAddict Engine 5 06-12-2008 05:12 AM
How to change the oil in your car montea Hotrodders' Lounge 1 10-21-2005 01:14 AM
Oil Preshure ve3ham Engine 9 10-28-2004 02:36 PM
