Oil Changes - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Who shakes the oil bottle before pouring?
Never 15 83.33%
Sometimes 3 16.67%
Always 0 0%
Voters: 18. You may not vote on this poll
Old 02-01-2019, 07:43 AM
chasracer's Avatar
True Hotrodder
Oil Changes
Old 02-01-2019, 08:42 AM
dwighty390's Avatar
Nobody....
The Following User Says Thank You to dwighty390 For This Useful Post:
Richiehd (02-01-2019)
Old 02-01-2019, 11:16 AM
fat tire's Avatar
fat tire
only if I drop it
Old 02-03-2019, 06:20 PM
chasracer's Avatar
True Hotrodder
There is some thought that shaking the oil before pouring will ensure that all of the various contents of the bottle are mixed. I have no idea of whether there is anything to it or not but it's certainly not going to hurt anything.
Old 02-03-2019, 09:14 PM
Old97's Avatar
So the oil drum attached to the guns at the quickie lube is just all out of whack and the guy that gets the oil change at the bottom of the barrel gets all the additives? And the first guy don't get diddly? Come on now.
Old 02-03-2019, 09:26 PM
Never shake it. But I do put on a new filter leaving the drain plug off and pour 1/2 a quart of the fresh stuff into the thing down the fill. It cleans some of the old out of the engine that is sitting in the heads/pan.
I change my oil every 2-5000 depending on how hard I have run it. Typically every 3000 or every 6 months.
Your oil is going to get mixed no need to shake the bottle.
Old 02-04-2019, 08:05 AM
dwighty390's Avatar
LOL no kidding...maybe they have agitators for the alleged "believers."
Old97 (02-04-2019)
Old 02-04-2019, 06:00 PM
CQNRQY
That's a new one on me
I've never even thought of shaking up the oil jug before using it.
I think it's more important to put some oil into the new oil filter so your oil pump doesn't run dry (cavitation prevention). Oh, and make sure you install the filter and pan plug before you poor in that thoroughly mixed oil...
Old 02-04-2019, 06:25 PM
The oil drums at oil change shops would never have a problem because they use it quick enough.
If a guy like you or me would buy a drum and take several years to go through it, then yes additives can settle out
Do a search for additive separation and you will find pics of empty oil bottles with “stuff “ at the bottom. That “stuff” are some of the additives that have precipitated out over a long period of storage. Some brands are worse than others, but it is a real and documented phenomenon.
For most people, it simply isn’t an issue. But I’ve got some oil that has been sitting for years, and those I do shake just in case. Fresh oil won’t ever be an issue though.
Old 02-04-2019, 07:32 PM
Old97's Avatar
I don't know man, The most oil I have ever bought was like 6 cases. A drum? When I was at the MOPAR dealer way back in the 90s a drum of HDX diesel oil would last a year. Back before everyone thought you need a one ton dually to pull a pop up camper or a John boat. How long did it sit plus new drums would sit in plant 3 for like a year or 2.
Old 02-05-2019, 08:26 AM
dwighty390's Avatar
Now why on Earth would the pump be any drier after an oil change than it would have after any other normal period of inactivity?
Old 02-05-2019, 10:08 AM
It’s a thing and it can happen
https://www.bobistheoilguy.com/forum...Number=1043912
Whether you choose to acknowledge or do anything about it is up to you as an individual.
For me I shake them if they have been sitting a while
Ymmv
Old 02-06-2019, 02:17 PM
dwighty390's Avatar
Originally Posted by meborder View Post
Itís a thing and it can happen
Ymmv
The same thing happens with beer. You should ALWAYS shake a beer vigorously before opening/pouring.
Old 02-06-2019, 02:21 PM
I something like that to one of my friends years ago on a road trip. he asked me to hand him a mt. dew from the cooler. so i gave it a vigorous shake right in front of him and handed it to him and said "here ya go!"
he paused for a second, looked at me and said "ha, ha, smart arse ... it's your car" and opened it up.
it would work with beer, too, though.
Old 02-06-2019, 05:39 PM
CQNRQY
When you replace the filter and don't put oil in it. You're relying on the pump to fill your filter up risking damage to your pump. You may run your pump dry until the filter fills with oil. It's Just a good practice that I learned working on hydraulic equipment.
Oil changes not recommended... ChevelleSS_LS6 Hotrodders' Lounge 17 02-08-2015 11:50 AM
How long before break in metal is gone from oil changes? ForceFed86 Engine 5 10-26-2010 12:58 PM
Wheel Load Changes With Weight Changes BillyShope Suspension - Brakes - Steering 0 02-24-2010 12:55 PM
Two questions about oil changes in a compressor Bugs Garage - Tools 6 11-08-2005 01:29 AM
my tran is vibrating when it changes gears !! guardianCherub51 Transmission - Rearend 2 07-23-2002 11:14 PM
