Oil Contamination in Air Lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2019, 10:26 AM
Molon Labe's Avatar
Last journal entry: Floors
The rings went bad on my reciprocating air compressor and when I drained it I got some milky tan oil/water mixture. I'm in the process of rebuilding the pump but I was planning to do some painting soon and I'm worried about the oil getting on the car. I'm aware of the various oil/moisture filters available but is there anything else I can do to remove the contamination that must be throughout my air lines?
Old 03-12-2019, 11:08 AM
ogre's Avatar
the 'Duracell Project'
any compressor will introduce oil into the air lines, if you don't filter the oil out for spraying it will cause havoc
air lines should gravity drain to a low point, the oil will gravity drain out the same way
you can assist this by removing the air fitting at the end and opening a 1/4 turn ball valve at the compressor
definitely wear hearing protection when doing this
Old 03-12-2019, 11:30 AM
Molon Labe's Avatar
My air system is properly plumbed to include drip legs for crud to collect in. From the tank the line goes into a 6' long, vertical, 1" black iron drip leg with a drain at the bottom. Then 1/2" black iron lines go horizontally from the top of this drip leg and at each drop the line comes up 10" from the horizontal line before turning down to the the air outlet. All lines continue past the last drop and are pitched to a drip leg at the ends with a drain at the bottom of the leg. I have had some of the oil/water sludge come out of the drip legs at the end of the runs so I'm pretty sure it's throughout the lines. I'm just not comfortable risking a paint job "hoping" the oil has been blown out. I need a way to flush the lines and tank. It's a 60 gallon tank so "sloshing" something around inside isn't going to work.
air lines, compressor, paint
Chevy 6.5 Diesel has no oil pressure again!!! dorksrock Engine 12 09-02-2012 08:51 PM
Is shop air safe for a fresh air breathing system? 777funk Garage - Tools 15 04-18-2012 10:40 PM
Oil for air compressor pump? smithkustoms Garage - Tools 24 03-22-2010 11:41 PM
Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines J.J. LASALLE General Rodding Tech 6 06-29-2009 01:04 AM
FRAM air breathers!!!! Robbie Engine 67 09-22-2005 05:52 PM
