Oil pressure sender as fuel blanking plug - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2018, 11:25 PM
I have one of those Holley fuel distribution splitter lines with the gauge. The gauge itself started leaking fuel today so I plugged the port it with a spare oil pressure light sender at lunch.
Will this do as a permanent fix? Or should I park ir until I get a proper blanking plug. I figure it's fine with the 7psi of pressure, but will the fuel damage it internally?
Thanks.
Sent from my GT-I9507 using Tapatalk
Old 11-20-2018, 05:15 AM
For a couple of bucks, go to Home Depot and get an 1/8" NPT plug. Don't take a chance with a fuel leak / fire. Not fun!
The Following 2 Users Say Thank You to '48 Austin For This Useful Post:
joe_padavano (11-20-2018), Makeshift (11-20-2018)
Old 11-20-2018, 07:07 AM
Old(s) Fart
Last wiki edit: Wheelbase database
Apparently "Makeshift" is an appropriate screen name...
Old 11-20-2018, 08:27 AM
You're right, the more I think about it, the crazier it sounds to chance it over a few dollars.
I smelt fumes as I pulled into work, and scrounged up the old pressure switch from my roadkit in the trunk to plug that hole so I could get it home in the afternoon.
Old 11-20-2018, 08:32 AM
Old(s) Fart
In fairness, I'd be lying if I said that I never made a roadside fix like that and then drove thousands of miles before making a proper repair...
The Following User Says Thank You to joe_padavano For This Useful Post:
Old 11-20-2018, 10:13 AM
Makeshift see picture. This could be you. It's not worth messing around.
The Following User Says Thank You to '48 Austin For This Useful Post:
Old 11-20-2018, 08:54 PM
Thanks.
NO! They can and do leak through their core, go to the hardware store and get the proper pipe thread plug which is probably a 1/4 NTP.
Bogie
The Following User Says Thank You to BogiesAnnex1 For This Useful Post:
Old 11-20-2018, 09:22 PM
Bogie
Thanks Bogie, sounds like the general consensus is that it's unsuitable (outside of a last resort get me home situation).
The correct blanking plug is indeed on it's way to me now.
Old 11-21-2018, 06:43 AM
55 Tony's Avatar
If you have fuel leaking inside the vehicle, you have bigger problems. No direct fuel pressure should ever go inside the vehicle. You use either an electric sender and gauge, or a fuel pressure ... I forget what it is called but it separates the actual fuel from a different line going into the cabin.
Old 11-21-2018, 07:43 AM
S10xGN's Avatar
Gotta love a turbo!
We've owned three Cadillac CTS's since 2004, the first two required (3) new OP senders due to leakage through the core centers. The '16 V-Sport hasn't had that problem yet...
Russ
Old 11-21-2018, 12:45 PM
Apologies for the confusion, it was just one of those cheapie gauges on the fuel inlet rail, No fuel inside the cabin.
Pics of a generic rail, and my 'repair'.
Funny thing is, I threw that old oil pressure switch into my kit just in case I needed to plug anything with a 1/8th NPT port. I thought it was overkill, but since it took up virtually no space I thought what the hell. It sure saved me a bunch of hassle having it handy this time around.
Electric Fuel Pressure Sender Location 72Orange Engine 6 02-18-2006 01:00 PM
oil pressure (idiot light) sender unit Mikebox Engine 1 03-23-2004 12:53 PM
Oil pressure sender question Jag Daddy Engine 5 03-07-2004 07:59 PM
oil pressure sender relocate?? saenz5 Engine 8 02-15-2004 05:05 PM
Oil Pressure sender locations? stonedchihuahua General Rodding Tech 5 04-24-2003 02:54 AM
