oil pump test - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2019, 12:03 PM
Husein-p's Avatar
oil pump test
Hey folks
I wanna to re use an oil pump after rebuild
But i wanna to know how can i test it before installing on engine
Because i dont have a lot of money for rebuilding engine so i wanna to know if his oil pump is healthy i wont change it
Some body can hlp me
Is my idea good or anyway i must change it with a new one ?
Old 09-14-2019, 12:29 PM
'49 Ford Coupe's Avatar
1949 Ford Coupe RESURRECTION
Take it apart, look at the gears very closely, check the clearance of the gears to the cover plate, put a straight edge across the body and it should be about 5 thousandths..watch this video (he doesn't check clearance)
https://youtu.be/8BlXUUeLmz0
Old 09-14-2019, 12:30 PM
chasracer's Avatar
True Hotrodder
For the few dollars a replacement costs, it's not worth damaging the other money (parts) that you have already put into the rebuild. I would let the rebuild sit until I saved the coin needed for the new pump rather than re-use a questionable pump.
Old 09-14-2019, 12:34 PM
Oh, and go here and pick a spring
https://www.summitracing.com/search/...l-pump-springs
Old 09-14-2019, 12:38 PM
Even if you buy a new one, do the same thing. Take it apart and check everything.
The Following User Says Thank You to '49 Ford Coupe For This Useful Post:
techinspector1 (09-14-2019)
Old 09-14-2019, 12:50 PM
Old(s) Fart
Last wiki edit: Wheelbase database
I think the problem is that shipping costs to the OP's location will be much greater than the cost of the pump.
Old 09-14-2019, 03:15 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Originally Posted by Husein-p View Post
Hey folks, I want to re-use an oil pump after rebuild, but i want to know how I can test it before installing it back on the engine.
I don't have a lot of money for rebuilding the engine, so i want to know if his oil pump is healthy. If it is, I won't change it.
You would be about the 50 millionth hot rodder who re-used their old oil pump.
In all my experience, nobody has ever told me that they fragged an oil pump.
Find a container. Put a 4 liters of used oil in it. Sit the pump down in the container and have a buddy hold it in place so that the pickup screen in just slightly off the bottom of the container so that the pump does not suck itself down to the bottom of the container and shut off the intake of oil. (tilt the pickup cone so that it is not parallel with the bottom of the container). Find an old intermediate drive shaft that connects between the pump and the distributor and cut off the distributor connector, so that you have a driveshaft you can connect an electric drill motor to. Chuck the shortened drive shaft into your drill motor and fit the shaft down over the slotted drive of the pump. With the drill motor running clockwise as you are looking down on the pump, fire up the drill motor and pump the oil out of the container (you did remember to allow a place for the oil to go didn't you?) A 1/4 inch or 3/8 inch drill motor, at top speed, should empty the container in about 10 seconds. A 1/2 inch drill motor runs slower, but should empty the container in less than 15 seconds. If the pump won't do that, purchase a new pump.
