Older Sata - any good? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2008, 09:18 PM
Guy is selling his Satajet HVLP model NR95 with 1.3 tip. He wants $80. Gun is in decent overall shape, comes with mini regulator and large aluminum cup.
Any opinions?
Thanks
Old 11-01-2008, 09:41 PM
milo's Avatar
point on positive
Excellent find, worth $80 with a smile
Old 11-02-2008, 01:17 AM
Thanks Milo for the reply.
What paints is this gun useful for? I've got some single stage I'd like to shoot (SPI) and they specifically recommend a 1.4 tip. I'll probably pick the gun up regardless.
Old 11-02-2008, 01:17 PM
Well, I went ahead and bought the gun for $75. Not the cleanest you'll ever find. The aircap and fluid tip look good. The 1 litre aluminum cup was in poor condition and the original Sata regulator's gauge was broken. Still, thought it was worth a gamble.
I'm going to tear it down completely and do a better job of cleaning it, then try a sprayout on an old hood I've got.
Old 11-02-2008, 01:34 PM
milo's Avatar
point on positive
I have a nr95 model that has been cleaned more than 5000 times and still shoots perfect... It has an internal air regulator that should be set at full open if you use the add on..I did replace the nylon type cup once and remember it was $60 alone.
Heres a fun thread that every project in it was sprayed with the Sata NR95..including primer,base and clear..count them if you can lol
http://www.a2zautoforums.com/showthread.php?t=4212
Old 11-02-2008, 02:33 PM
Milo, thanks for the encouraging reply. What size tip or tips have you used in the gun?
I've already got a spare litre cup that will fit. It's an Astro brand. I can get a gauge from work.
Can't wait to try this gun.
Old 11-02-2008, 06:12 PM
302 Z28's Avatar
Hate to rain on your parade, but I had use of one of those when I was painting my 34. To be quite frank, my Harbor Freight 43430 sprayed better. The gun was in very good shape and clean.
Edit, went back and checked my post from a few years ago, it was a SataJet 92, not a 95...sorry.
Vince
Old 11-02-2008, 06:49 PM
milo's Avatar
point on positive
The tip that they come new with is a 1.4 though it isn't marked..
Any gun that can be cleaned over a thousand times and still go back together and spray without stripped threads etc, is a good gun.
Some of the knock off guns fail at the first cleaning and never spray the same way twice...
Store your guns with a bit of thinner (1oz) in them in an upright position .. The Sata I use almost daily has never been dry (13 years now https://www.hotrodders.com/forum/i-ne...=weapon+choice )
Old 11-03-2008, 06:10 PM
[email protected]
Fish..... If you don't like that Sata, contact me and I will give you the $75 that you paid for it. I have used both, and there is no comparison between the HF gun and a Sata 95. The HF gun, if you get a good one, is possibly good for a couple of projects, before the quality goes out the door. The Sata, if almost taken care of will last for a long time. If really taken care of, it will last a lifetime.
Aaron
Old 11-03-2008, 06:23 PM
302 Z28's Avatar
I said the HF gun sprayed better than the NR92 I was loaned. I would not attempt to compare the HF gun to the NR95
Vince
Old 11-03-2008, 11:11 PM
Aaron
That's something for me to consider, but most likely, I'll be hanging onto it.
Thanks for the offer.
Do you guys think it would be worth it to buy a 1.4 tip and aircap for it?
I'm going to spray SPI single stage black. Of course, I'm going to give it a decent spray test before committing to use it for my project. Also, typically, what distance do you recommend from gun to surface being painted with this Sata?
I've got to get a new gauge for the mini Sata regulator on it. I was impressed with the quality of the old gauge. Had some heft to it, all metal, not like the plastic mini regs Harbor Freight supplies with its' guns.
Old 11-06-2008, 10:40 PM
milo's Avatar
point on positive
Does it say 1.3 on it ?
I would say to try it like it is and if see how it sprays..If you don't like it I'll give ya $85 for it
Old 11-07-2008, 08:18 AM
Yep, it says Sata NR95 1.3 on the aircap.
hmmmm.........$85................not yet, but thanks for the offer.
And, Milo, I looked at most of the projects shown on that post you linked.
Very impressive, to say the least!
Old 11-07-2008, 11:23 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
I'd spray some of that SS first with it before making a judgment.
I've shot a lot of SPI's SS and with a 1.3 does fine,just have to go a little slower so you get enough on panel for good flow out. If you have some Universial Clear & Slow cat. try it instead,Same thing.
Rumor had it that Sata's tip size was downsized in order to be compliant with the rest of the World,mostly Australia and "some" 1.3's ARE 1.4's.
Is it a "real" regulator or a choke valve?
Old 11-07-2008, 03:25 PM
The gun's got the Sata regulator shown in the link below, although my gun's regulator is the same green color as the gun body. Besides having SATA 1.3 NR95 on the aircap, it has the number 1395 on it's fluid tip.
http://www.sjdiscounttools.com/sat27771.html
Older Chevy Block, Newer Fuel Infection texascaraudioman Engine 1 10-05-2008 11:51 AM
Mail order dry good supplies? SLR_65 Body - Exterior 1 09-29-2007 01:43 PM
Ingersol Rand Paint Gun Like Sata 2000?? camaro freak Body - Exterior 1 05-13-2006 01:22 PM
woud this be a good setup? speedy123 Engine 16 05-22-2004 09:18 PM
Is this Duster a Good Buy? Nightfire Hotrodders' Lounge 17 03-18-2004 04:38 PM
