This is one OLD Jump starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2018, 04:07 PM
bsa_bob2's Avatar
This jumper i purchased maybe 20 years or so ago.Its worked up until today pulling my sons low ride 87 chev S/b/It did doesn't ever show a complete charge,on the indicator gauge.Question is;Can the batteries be changed in these or are they" throw away" tool. no screws anywhere.no holding clips.Hate to throw it out, been here longer than my dog.~are you going to say just buy another one? any help appreciated bob s
Name:	jump starter battery 001.jpg
Old 05-29-2018, 06:06 PM
dusterdude3404's Avatar
Some are replaceable
Sent from my R1 HD using Tapatalk
The Following User Says Thank You to dusterdude3404 For This Useful Post:
bsa_bob2 (06-20-2018)
Old 05-29-2018, 06:28 PM
bsa_bob2's Avatar
Who would know here! need to find out if and if not batterie replaceable/ bob s
Old 05-29-2018, 09:13 PM
Rip VW's Avatar
I will endevour to persevere
Last journal entry: This thread is officially Kaput as of 11/07/2017
Bob, I have a jump box very similar to yours. I wanted to know If it had replaceable batteries too.
So I took it apart carefully and it wasn't easy, and what I found in the box was a 12 volt Sealed Gel motorcycle battery. I just so happened to have a Sealed lead acid motorcycle battery that fit the dimensions of the original. as this battery was in good shape and the old battery had a bad cell. I put my replacement battery in and it works great. I been using the heck out of it. I have a Interstate battery charger float maintainer and it works great to recharge the box.
Go ahead and take it apart, If it doesn't have a Motorcycle battery it may have a big bank of C type rechargeable batts all soldered together. There are some places online that if you contact them and send them your old battery bundle they will make you a new bundle and it is pretty darn cost effective!
I was going to throw this box away but I love to take things apart to see how they work and I was surprised at what I found..
Update: I had to open the seam on my box but I was able to fit it back together and used a couple of dots of glue.
One quick note of caution. Use only SLA (sealed lead acid) of Sealed Gel battery if you use a MC battery. You don't want to have acid leaking in the box especially when you sometimes stand the box upside down to reach battery terminals on a battery!
Last edited by Rip VW; 05-29-2018 at 09:20 PM. Reason: Replaced fractured dilithium crystal, All tests Normal
The Following User Says Thank You to Rip VW For This Useful Post:
bsa_bob2 (05-31-2018)
Old 05-30-2018, 07:20 AM
Wiki Edits: 31
Yeah, they use what is basically a power wheels battery but a SLA motorcycle battery works too. Newer ones have a battery door for easy disposal.
Old 05-31-2018, 07:03 AM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
On things like that, where no fasteners are apparent, they hide them under the label. Run your finger over it with moderate pressure and see if there are indents where screws may be located. Poke a small hole and see what's in there.
The Following User Says Thank You to Too Many Projects For This Useful Post:
Old 06-18-2018, 08:54 AM
bsa_bob2's Avatar
Thanks for all the tips on this subject . gonna look it over today -95 degrees hi humdity terrible outside
Old 06-20-2018, 05:39 AM
bsa_bob2's Avatar
got a new battery -- replaceable-- 10 screws took it apart all good now thanks bob s
Old 06-20-2018, 09:51 AM
bsa_bob2's Avatar
btt btt btt
tach jump tomthecomic Engine 2 09-08-2007 07:09 PM
Time to jump on in.... ls427ss Introduce Yourself 2 12-22-2005 12:54 AM
forum jump troy-curt Hotrodders Site Suggestions and Questions 3 06-21-2003 01:57 PM
