Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Optimal Stroke for Big Inch SBC
Old 06-25-2018, 06:32 PM
tyler2you's Avatar
tyler2you tyler2you is offline
I've been reading up on supercharging/turbocharging and the more research I do, the more I think something like this might be a better option for me:
https://blueprintengines.com/collect...cts/gm-454-ps2
563 HP / 545 FT LBS with a 30 month/50,000 mile warranty. I'd be interested in seeing the dyno plot to see where this thing makes power. Only drawback is I'd have to save my pennies for a while and couldn't piece it together a little bit at a time.
I see so many cases where someone makes a mistake with timing, fuel ratio, or gets some bad gas and does permanent damage with a boosted platform. The NA approach just seems to be a lower risk approach, albeit at a higher cost per HP.
