Optimal Stroke for Big Inch SBC - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-26-2018, 06:34 AM
vinniekq2's Avatar
I don't see your math?
build engine "X" amount?
build engine "X" amount plus "X" amount for boost
build 421 cube N/A engine about the same hp about the same price
note original question about best "stroke" for a large small block
the 454 may or may not have issues with head gaskets and there is no room for over bore.
build a 440 cube if you want to use all of the bore you can and still be able to rebuild
If you absolutely must have the biggest small block? Then use a talldeck and go 472. Gonna get expensive,,,
Im not familiar with "Blueprint" brand blocks/cranks/rods?
  #17 (permalink)
Old 06-26-2018, 07:58 AM
tyler2you's Avatar
I gave up on the detailed math after looking at the cost of doing a Vortech/Procharger or Weiand blower and a forged lower end. I would also want to upgrade my ignition to something electronically controlled. It starts to add up quick for supercharging. I'm sure turbo can be done a lot more economically, but I'm not looking to do that much custom fabrication.
I agree that it's probably smart to limit the cubes to 440 or maybe 427 to allow room for a rebuild down the road.
  #18 (permalink)
Old 06-26-2018, 08:15 AM
vinniekq2's Avatar
You need to PM Richard 9Techinspector) He can help you with the back 1/2 of the car. A 500 hp engine in a "Shakey" II is a dis aster to drive with out serious front and rear mods. If all chassis work is done then all is good,,,
The Following User Says Thank You to vinniekq2 For This Useful Post:
Moosecountry (01-09-2020)
  #19 (permalink)
Old 06-26-2018, 09:38 AM
tyler2you's Avatar
Good points. I put in a MII IFS (TCI) up front, but have the single mono leafs in the back with a Ford 8 inch and traction bars. I've been looking at subframe connectors and an independent rear set-up with a Ford 9 inch, but the price is pretty steep.
  #20 (permalink)
Old 06-26-2018, 10:01 PM
vinniekq2's Avatar
If you stick with the mono leaf?
50/50 rear shocks
traction bars need to bolt to the spring mount plate(not clip ons). The traction bars may need to be lengthened, The snubber must at least reach the spring eye. The right side snubber should be preloaded to touch spring eye and left side about 1/2" clearance. Sub frames must be tied. Rear end will need a positive axle retention system.
If you follow a good recipe I can see low 11s easy
tyler2you (06-27-2018)
  #21 (permalink)
Old 09-12-2018, 06:22 PM
I ran a mild 454 with a 671 and made 627hp and got 13mpg on a trip in a heavy bucket (2500 lbs) with 3.0 rear gears. Ran low 10s on the quarter on pumpgas.
A mate with a way lighter bucket and a wild 350 ran 10.6 on the quarter - he probably weighed a good 500lbs less than my car, so probably a bit over 500hp. His engine really needed a lot of revs to get to its power band.
Both cars were street driven a lot, and raced over summer. He took mine for a drive once and commented how it had heaps of low down torque and you didnt have to rev it to move along quickly.
My motor was a 2 bolt 454 with cast crank - got it double key way'd. I got the factory rods shot peined, and from Summit I got some TRW forged blower pistons (about US $600) and a Comp Cams hydraulic flat tappet blower cam (about US$300). I changed the stock heads for some second hand alloy Bow Ties and including the second hand 671 and the new ignition, the whole deal cost me around US$5500.
So under US$9 per horsepower. I thought that was great value.
I have seen big inch SBC engines that (over here) cost over US$40,000 that make around 800hp so thats US$50 per horsepower.
Blowers can be cheap horsepower.
Keys to making them work on a budget is good low comp forged blower pistons, double keyway the crank, and fit a decent ignition system. Forged everythings are great if your budget can handle it - my next engine was a blown 540 with new everything and that cost about US$20,000 and made 851 hp so US$23 per horsepower.
  #22 (permalink)
Old 09-12-2018, 07:19 PM
400” bore x 3.00” stroke = 302 cu. in.
This engine was a proven winner at SCCA races
In 1962-1964 I had a 1956 Chevrolet with a 1958 block which was bored to a 302 CI engine. Three speed transmission and overdrive. It was one of the best runners i have ever had.
  #23 (permalink)
Old 09-13-2018, 07:11 AM
[QUOTE=tyler2you;4600250]
- 80/20 street/strip with good street manners
- Strong torque from 2500 to 4500. Thinking something in the 500 lb ft/500 hp range. Don't want to have to spin it over 6000
- Solid reliability/longevity
- Can run on 91 octane
A stock late 60's early 70's Cadillac 472/500 checks those boxes. Need to run 93 due to compression, do some head work, timing chain, recurved hei, and a few other things. But out the gate your talking 300/450ft lbs in a high nickle block weighing between a 350 and 454 with stock heads.
I would find a entire rusted car and use the th400 or maybe manual valve body 4l80. Give the motor a mild rebuild and run a newer carb or self learning efi.
  #24 (permalink)
Old 09-13-2018, 01:08 PM
I'd put in an LS motor and be done with it. The sky is the limit on power and they last.
The Following User Says Thank You to '48 Austin For This Useful Post:
64nailhead (09-13-2018)
  #25 (permalink)
Old 09-13-2018, 03:27 PM
64nailhead's Avatar
And when they don't, another 4.8 or 5.3 is $300 away. Add a cam and springs + the boosted things - it's so hard to turn down. The OP hasn't revisited, but his plan with an SHP 400+ cube build at 10 psi makes 500hp seem almost free (to me). Once you get the past the cost of his long block and $1000 of TB EFI stuff, he would be wondering why he never did this before.
  #26 (permalink)
Old 01-25-2019, 05:19 PM
arnoldsel's Avatar
Update?
So what did you do? I like the LS with a Pro Charger or the cheapest type of those blower. With an LS you can get the computer of which you can also tune for these blower. Had a 97 Vette and also a 350 Vortec Head Built to similar horsepower. Sorry the LS is such a better engine. No leaks and just a better smoother engine. I am really looking at a change to one some day.
  #27 (permalink)
Old 08-13-2019, 02:10 PM
bentwings's Avatar
bentwings
If you look through Skip White’s site you can see his views on big in SBC. He likes the 425 in one.with a nice low end roller cam and a single 800 Holley or Edelbrock port EFI would be a wonderful street motor even in a heavier car.
I’d use a good 4L60e electric. OD and about a 3.42 gear. It would be a great street car and good racer. Not the fastest but very reliable and a pretty good bracket car. Plus that big cu in sbc would have a really throaty sound.
  #28 (permalink)
Old 01-09-2020, 09:50 AM
55project's Avatar
We run a Naturally aspirated 421 SBC in my daughter's 69 Firebird . ( No electronics and on foot brake ) Great lil motor, make right at 700 hp. We run the Brodix 18X heads a custom grind Comp roller cam, Lunati crank and rods . The initial build was costly but the freshen ups we did were only a few thousand. Here's a video of her and the car after we did a freshen up. Enjoy and Good Luck on what ever you decide
  #29 (permalink)
Old 01-14-2020, 09:34 PM
https://www.youtube.com/watch?v=D_kkUxs8utM
I like that Gremlin!
  #30 (permalink)
Old 01-16-2020, 01:31 PM
55project's Avatar
The Gremlin is my buddy Bill car, That's a twin turbo SBC. And that's one of his son's running against my daughter. Pretty cool to see them both up at the line together .
SBC big stroke opinions please bigmac73 Engine 12 01-21-2015 06:08 AM
400chev standard stroke 6 inch rods clunking sik400 Engine 6 06-19-2007 09:55 PM
3 inch stroke in a 400sbc? kuhn-77 Engine 10 02-03-2007 08:20 PM
4.00 inch stroke crank in a stock gm 400 block sb72elcamino350 Engine 27 12-24-2006 11:17 AM
big blocks optimal operating temperature 70SPORT Engine 1 04-07-2005 01:48 PM
