overdrive automatic in a gen2 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2019, 11:27 AM
what do i need to do to install a late model automatic overdrive transmission in my 78 camaro?
Old 09-09-2019, 11:37 AM
BigMo's Avatar
Cross-member move, potentially driveshaft cut/length change depending on what trans is used. Appropriate trans mount, relocate/adapt trans cooling lines
Sent from my SM-G900V using Tapatalk
Old 09-09-2019, 12:04 PM
what im wondering about which is the best and simplest trans to use ,the car is going to be carburated for at least a couple more years, but i read so much stuff on doing the lockup but i dont want to screw the trans up,im retired and working on a strict budget . The cars going to be a show car with an occasional trip to the strip.its got a mildly built 383 stroker with a a 3:55 posi.
Old 09-09-2019, 12:16 PM
BigMo's Avatar
Typical 700r4 will work but must hve correct canle set up to prevent trans from burning up
Old 09-09-2019, 07:50 PM
With 3.55 gearing you don't need overdrive. Keep your cash and just enjoy driving the thing 60mph down backroads more.
For a show car you dont need to be going 90 down the highway. When at the strip that brief 120mph 6000ish rpm or so pass wont do enough damage to justify installing a failure prone 700.
Only place where a 700 shines is the lockup.
For what it sounds what your planning on doing a lockup is not necessary.
If you want stupid simple, reliable and in your case cheap(already installed cost nothing), a th350 or th400 will work just fine.
The Following User Says Thank You to cerial For This Useful Post:
RWENUTS (09-09-2019)
Old 09-09-2019, 09:22 PM
BigMo's Avatar
...that was supposed to be "cable", the TV cable
Old 09-10-2019, 05:26 AM
75gmck25's Avatar
Last journal entry: Engine replacement
If you are on a budget, the TH350 is inexpensive to purchase and maintain, and there are many places that can modify it so it lasts longer for racing. The 700R4 overdrive is really only useful if you want to cruise at highway speeds for long periods.
Bruce
