Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Overheating small block chevy
  #21 (permalink)
Old 07-30-2015, 03:21 AM
64nailhead's Avatar
64nailhead 64nailhead is offline
Intake manifold next to the t-stat. I didn't see where you posted what intake you're running, but most have a port in that area. The idea being that the fans are following thermostat command. And not to state the obvious, but use a fan switch that is rated 5-10 degrees higher than the thermostat, otherwise you'll have the fan running to cool water that is not flowing from the engine.
Good luck - Jim
