Overheating small block chevy - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-17-2015, 05:56 PM
Was that a four core with trams cooler rad?
  #17 (permalink)
Old 07-17-2015, 07:04 PM
Resident Racer
Click here for the radiator I bought. It's been great since I installed it to replace the stock radiator I had. It's a two core but each core is 1" wide while stock cores are only .5" wide so you get better cooling from increased surface area.
Can't recommend this radiator enough. It's really helped with my overheating problems.
EDIT
Also, make sure you have a properly aligned fan and shroud system. Shrouds really help maximise the radiator's efficiency.
  #18 (permalink)
Old 07-17-2015, 08:53 PM
Did you stick with the stock mechanical fans or go electric?
  #19 (permalink)
Old 07-17-2015, 09:34 PM
Resident Racer
Went with my five-blade mechanical flex fan with shroud from my previous setup. Never looked back to going stock radiator from that day on. I don't know if twin electric fans are going to improve what I already have but at 170 just driving around with my current setup and 190 sitting in traffic, what more do I need?
  #20 (permalink)
Old 07-29-2015, 07:08 PM
I ended up buying a Griffen combo radiator with dual electric fans. Still working on the install. Anyone got any ideas on best location for the temp sensor on the standard 194 GM heads for 350? I have my temp gauge on the left side head by the headers between cylinder 1 and 3 now.
  #21 (permalink)
Old 07-30-2015, 03:21 AM
64nailhead's Avatar
Intake manifold next to the t-stat. I didn't see where you posted what intake you're running, but most have a port in that area. The idea being that the fans are following thermostat command. And not to state the obvious, but use a fan switch that is rated 5-10 degrees higher than the thermostat, otherwise you'll have the fan running to cool water that is not flowing from the engine.
Good luck - Jim
  #22 (permalink)
Old 07-30-2015, 06:52 PM
It's a weiand intake with a 142cid blower, there is a port on right side by the alternator bracket that I can use. I was worried that the aluminum intake would leak with the steel fitting and no thread lock as it affects conductivity. Thermostat is 180 and the fan control is 185.
  #23 (permalink)
Old 08-08-2015, 08:34 PM
I installed the Griffen radiator with dual electric fans. Everything seems to be working fine . I let it idle for 20 mins and the fans came on. Temps showed to stay between 190 and 200. The fan switch is on when temp in intake gets to 185 . I also increased my timing to 14 degrees. Still have a heavy presence of unburned fuel when idling and kicking down the gas pedal (black smoke) and stains the driveway. I think next steps would be to install a wideband O2 sensor kit to measure the fuel to air ratio.
  #24 (permalink)
Old 08-11-2015, 05:24 PM
What thermostat are you running?
camaro, overheating, radiator, timing
overheating small block chevy wildjeffpa Engine 31 06-13-2017 02:44 PM
350 small block engine overheating myhotride Engine 14 02-11-2012 03:08 PM
350 small block overheating.. 69 impala! sj69impala Engine 13 10-29-2009 09:57 PM
Chevy 350 long block overheating jeff79 Engine 91 08-28-2009 02:45 PM
Track Car Overheating, small block Ford RAW Engine 15 12-16-2003 10:25 PM
