Paint Mix Cup - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2017, 01:50 PM
tractormanmike's Avatar
Paint Mix Cup
So I'm painting my 87 ram cab and the paint calls for 8:1:1 ratio. My gun has the 20 oz cup. The only mixing cups the store had at time was 32 oz.
With no 8:1:1 ratio section on it. So he said I can mix it by using the section were it list 20 oz
So 8:1:1 would I go 18 oz paint 1 oz activator 1 oz reducer to = 20 oz total?
It's my first time doing this lol
Old 10-26-2017, 01:57 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would use 8 oz paint 1 oz activator and 1 oz reducer. 8:1:1
To double the amount it would be 16 oz paint 2 oz activator and 2 oz reducer. Always mix the smaller quanity and spray a layout to see that the material and gun adjustment are working for you.. Even the pros do this when dealing with a new or unfamiliar material..
Sam
Old 10-26-2017, 08:56 PM
idrivejunk's Avatar
Grand Prix user
Last journal entry: Last look
Use a can, with straight sides, and make ten equal marks on a stir stick the right size to have the amount you want to mix at the top of your marks. Pour first ingredient to the eighth mark, the next to the ninth, and the last to the tenth.
Old 10-26-2017, 10:18 PM
Let's just make this clear, NO! That would be 18:1:1!
I have a number of mixing sticks like this. They should have one at your paint store. Here is one on ebay. https://www.ebay.com/itm/PPG-DOX-384...-/282391036123
As mentioned by idrivejunk the sides of the container have to be straight!
If you wanted about 20 oz you could simply go to 16, then add 2 and add 2. That's the same as 8:1:1.
Mixing cups will also have ounces too, and you can do the same thing.
Just remember 8:1:1 or 16:2:2 or 32:4:4 are the same.
Old 10-27-2017, 03:07 PM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
And If you want less, then its 4:1/2:1/2. You can use the 4:1 scale but only use 1/2 of the 1 then the other 1/2 of it.
That ratio sounds strange, Be sure its 8:1:1 and not 8:2:1
Old 11-19-2017, 06:07 AM
Wiki Edits: 11
Everyone should have a mixing stick with the ratios on it.
In my case I find that my mixing cup usually has dried paint in and on it and needs cleaning so I get the stick out which is also covered in dried paint and in need of cleaning just so you can see the numbers. if that will take to long I'll just get a regular old wood, paint stick and make a ruler, using a sharpie and a ruler I transfer the inches onto the paint stick. If I want 4:1 its 4" and 1" totaling 5". If its 4:1:1 that would be 6".
If 8:1:1 is to much material for the cup that way then you use the 1/2" instead of the 1" marks so it ends up with a mark at 4" another at 4 1/2" and one at 5"
Most of the time I use the empty vegie and soup cans from home with a mixing stick since clean up isn't my speciality and I cant seem to ever throw out my dirty disposable mixing cups.
A lot of the time you can use an air blower and blow out the dried paint in a cup ,that's pretty quick way to clean one but it don't always work.
iwata lph400 paint cup the nitro man Body - Exterior 3 12-22-2011 06:38 AM
Paint cup question rideblue0 Body - Exterior 5 06-09-2008 05:07 AM
Mixing Cup Paint Ratios & Percent by volume x711 Body - Exterior 4 02-28-2006 06:49 PM
Paint cup with impeller in it for metal flakes. MARTINSR Body - Exterior 11 01-31-2006 03:40 PM
Nextel Cup Tickets? (Winston Cup) bonuts Hotrodders' Lounge 5 01-12-2004 09:21 PM
