Paint shrivels after recoat - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 07-02-2014, 01:40 PM
Hello everyone. I am new to the sight and haven't had any luck finding a post with the same problem I am having. I am painting an old steel bicycle with acrylic enamel paint by rustoleum, I primer, seal, base coat, wet sand the base coat with 600, then when I reapply the base, the paint starts to get these raised veins all over my project. I have no idea what is causing this. I wait about 30 minute after wet sanding before recoat. I hope someone could shed some light on this for me. Thank you.
Saul
Old 07-02-2014, 01:53 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Too much product too soon.. You may need 24 hours of flash time before recoating with that product..
Sam
Old 07-02-2014, 02:32 PM
Sam
The primer I let sit for 12 hours. the sealer I let sit for 1 hour before basecoat. the basecoat was left 6 hours before wet sanding and recoat. Should I allow a full 24 hours in between stages to ensure that the "veins" do not appear? Thank you for the quick reply.
Saul
Old 07-02-2014, 07:16 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Acryic Enamel doesn't require a clear coat. Is this an aerosol product? If so, you should allow at least 24 hours before trying to sand and reocat if there is a problem with the finish. Be sure to read the tech sheet or instructions on the can, as each manufacturer has different spec on how to handle problems.
Kelly
Old 07-02-2014, 10:32 PM
Kelly
Would it be alright if I do add additional clear coat to the acrylic enamel? This is an aerosol product. The can falls short of instructions but I will comb the net for a more specific tech sheet..
Saul
Old 07-02-2014, 10:43 PM
Yes it should be fine to use a clear coat over the enamel, but make sure it is a urethane or enamel based clear coat. If you spray a lacquer based product over the enamel it will look like you used paint remover. There should be instructions on the can that tell recoat times, dry to touch times, etc. You should not attempt to sand and recoat it before the recommended recoat time.
Kelly
The Following User Says Thank You to carolinacustoms For This Useful Post:
saul_baron (07-02-2014)
Old 07-02-2014, 11:40 PM
Kelly
Thank you very much. I will make sure to keep any lacquer products off the project.
many thanks.
Saul.
Old 07-03-2014, 09:36 AM
johnnyg's Avatar
hold my beer and watch this!
Saul
Apply lighter coats as well. I had the same problem on my sons bike! LOL 1st light coat went good, 2nd heavy coat had the wrinkly coat.
Old 07-06-2014, 08:50 AM
Last journal entry: Still running strong
DON'T SAND IT OR SCUFF, not unless its months old. It looks dry & feels dry but under neath the top coat its still gassing out Rustoleum takes a long time to set up, like weeks. You can respray it as much as you want, just don't sand on freshly painted Rustoleum an expect another coat of paint on top of that to stay.
acrylic enamel, bicycle painting, paint, vintage bicycle
how long do you have to recoat clearcoat millermax Body - Exterior 3 05-01-2012 04:34 PM
Sanding SS urethane paint before recoat ka24deroadster Body - Exterior 9 07-01-2009 06:41 PM
recoat windows 66 Restomod Body - Exterior 3 10-02-2008 10:53 AM
paint recoat times... MikeP Body - Exterior 3 04-27-2007 12:24 PM
mp 170 recoat oldred Body - Exterior 4 12-08-2004 01:39 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
