painting galvanized metal - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2018, 08:47 AM
39 master's Avatar
Scored a swamp cooler that needs a little TLC. It's galvanized metal that needs a fresh coat of paint. Question is, how do I get paint to stick to it?
Name:	swamp cooler 003.jpg
Old 04-20-2018, 10:27 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
First a good scrubbing is mandatory.. The green scrubbies your wife uses for dishes and Dawn with hot water.. hot as you can stand will work to get the surface clean. once it is clean there are a number of galvanized primers that can be used. once the prime is done then a color of your choice is used.. Some say sand it which might work but I want it as clean as possible before any sanding..
Sam
Old 04-21-2018, 05:49 AM
Forty2door's Avatar
Swamp cooler
After cleaning and scrubbing, I've always wiped the surfaces down with vinegar. Perhaps old school by now.
Old 04-22-2018, 05:08 AM
I've done the vinegar trick also. It works.
Old 04-22-2018, 09:18 AM
And epoxy primer is a good way to go too.
Old 05-02-2018, 11:14 PM
put up or shut up
I don't really paint galvanized metal but thru training I recall reading that you use etch primer OR use white vinegar then rinse with water with a little baking soda and then prime with a DTM primer.
galvanized coating painting? brandonA. Body - Exterior 12 02-15-2011 07:31 AM
GALVANIZED METAL "BLANCHING" CHEVY NUT Body - Exterior 1 01-22-2007 06:37 PM
Painting Galvanized metal Madd Syntst Body - Exterior 22 09-23-2005 11:33 AM
Can galvanized sheet metal be MIG welded Slickriffs Body - Exterior 9 09-16-2004 07:19 AM
Newbie with ? about Painting Galvanized Metal 1BadHawk Hotrodders' Lounge 4 05-25-2003 04:26 PM
