Panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2005, 09:41 PM
Panels
Hey
What would an Alloy Bonnet go like? Would it be very weak or rust quickly? Just wondering cos its very easy to beat into shape.
Thanks
Troy
Old 01-24-2005, 11:19 PM
Randy Ferguson's Avatar
Ferguson Coachbuilding
Last journal entry: '41 Chevy sedan
Troy,
Could you please be more specific with you question?
When I think of alloy, I immediately assume you're talking about aluminum.
It won't rust.
Your bonnet will be as strong as you want it, according to how you build it.
I'm not sure of the designation for alloys in Australia, but in the States, we normally use 3003 H14 .063
To clarify:
3003 is the alloy
H14 is the hardness rating, which in this case is half hard.
.063 is the thickness, of course
With this material, it's not necessary to anneal. In fact, I wouldn't suggest it, as it will make too soft for automotive panel work, which will result in a panel that dents very easily. You would only anneal it in an area where there is deep drawing and the material needs to stretch a substantial amount. Even at that, you would only spot anneal it.
If you could post pictures of what you're working on, that would be super!!
Randy Ferguson
www.metalmeet.com
Old 01-25-2005, 03:54 AM
Hey Randy Ferguson.
Thanks for the advice man! As of right now I'm working on a design. It will basically be a different car, I'm just looking for a car that has what I want. SO I can build off of it, so to speak lol! Yeah sorry when I say alloy I mean ALuminium! Oh and just a quick question, what does anneal it mean? have a good one man! Thanks for your reply!
Thanks
Troy
Old 01-25-2005, 09:13 PM
Hi Troy,
Anneal means to soften by heating to a certain temperature and either water or air quenching.
A couple easy ways to go about it are to mark the panel with a wide tip permanent marker, in a grid pattern with the marks about 1"-1.5" apart. You then use either an O/A torch or a propane weed burner to heat the panel to point of burning off the ink. Don't heat it beyond that or it may melt, ruining your panel. The other way is to use the O/A torch with an acetylene rich flame to apply a layer of soot to the panel, then by turning up the oxygen or using the weed burner, burn the soot off. Again, don't go any hotter than it takes for the soot to burn off or you'll have a pile of molton aluminum on the floor!!
As previously mentioned, I wouldn't suggest annealing unless it's absolutely necessary.
I'd love to see what you have in mind.
How are you going about designing what you want??
I normally build a quick buck from 1/4" hot roll rod to get an idea of how the finished product will look.
Old 01-26-2005, 06:19 PM
Hey
Thanks for the description man! Thats really helpful. For the designing its mostly just pencil and paper, computing stuff confuses me loL! I'm just moulding a small size clay to see how it will look and then I will go into the difficult stuff! If you ahve any advice! I"M ALWAYS OPEN TO SUGGESTIONS! lol! Thanks for your help man! If I get to scan the image, I'll try get it to you so you can tell me what you think!
Thanks
Troy
Old 01-26-2005, 09:20 PM
Hi Troy,
Scratch building, eh!!!!
That's the best way!! You're sure to get everything you want. Sounds like a fun project. I can't wait to see what you have in mind. I'm more than happy to give any advice I can. I've been involved in building a couple scratch built cars. It's a lot of fun!
Randy
Old 01-27-2005, 01:31 AM
Hey
Yeah the only way to go, you can get everything you want that way, like you said! Well I'll try to get the sketches scanned sometime! Sweet man, thanks for offering to help!
Thanks
Troy!
Hey
Thanks
Troy!
