Patching Advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2008, 10:25 AM
Patching Advice
Looking for any good tips, On my 66 Nova Ive currently got the quarter panel off and Im wanting to fill and get rid of the stock antenna hole. Im planning on placing a piece of sheet matal under it and tacking it in anf filling the hole with weld and smoothing it out? Is this a good method.
Old 11-21-2008, 10:34 AM
Henry Highrise's Avatar
Lost in the 60's
Last wiki edit: Removing stuck fasteners
Wiki Edits: 4
That is a good way to do it. Any pin holes in the welds or grinding marks or whatever can be smoothed up with a little spot putty.
Old 11-21-2008, 12:06 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Depending on the size hole,I have used "knockout's",the round slug for the conduit connectors,from metal electric box'x for patchs. I've done what your talking about and used a fiber strand type filler to fill it with but now that I'm a better welder,I prefer to make things fit and butt weld. You can tack a piece of mig wire to hold it up with or a stud from a stud welder. Magnets work too but you have to be carefull and remove them quickly as the welding will ruin them.
Old 11-21-2008, 01:08 PM
why even risk ruining a fender by welding????
just cut a sheet metal backing patch about 1" bigger than the hole and "panel bond adhesive" it in place on the inside of the fender...
be just a bit generous with the adhesive and let it ooze onto the exposed side, smear it around to level it some....
the glue is totally water tight once cured to protect the patch and does sand to be a first filler layer....
then just a skim coat of regular filler to fill/blend all into the fender....
Old 11-21-2008, 01:45 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
That method would be likely to get too much heat into the metal and cause a warp or blowthrough ,,,,, Much better to but weld one in or use one of the other methods outlined..
Sam
Old 11-21-2008, 01:47 PM
I say, if you have the skills and tools to weld a quarter on, you certainly have the skills and tools to weld a plug in that ant hole!
Use a piece of the old quarter panel, same thickness metal, easier to weld.
You could "plug" weld it in by putting the patch under it, tacking it in place and then weld it up solid around the seam. Then fill it with a good filler.
OR, put your patch under it, then scribe around the edge with a sharp scribe. Then cut the patch out on that line, put it in holding it with a magnet or clamp and tack it in place. Weld SHORT beads letting it cool a LONG time between welds until the whole seam is welded up.
Of course, once you learn to control heat and work metal you would weld it and work the metal long the way. But if you aren't experianced, weld short welds and let it COOL a LONG time between welds so you don't warp the metal.
Old 11-21-2008, 02:15 PM
Oh yeah, and another thing is most adhesives "don't like" filler. So filling over them is going to open the door for failure. If you epoxy prime over it, then filling with body filler is ok.
Old 11-21-2008, 03:08 PM
Brian is correct....
some of the panel bond adhesives are epoxy base, some are acrylic base and the single part adhesives are mostly urathane base so there can be a compatibility problem with direct filler application...
(read the specific tech sheets for that specific glue)
here's a link to some "how to" video's to better explain the procedure:
http://www.lord.com/Home/ProductsSer...3/Default.aspx
Old 11-21-2008, 03:23 PM
Well thanks everyone, I wanst worried about welding as im currently replaceing the skins on both quarters. Im done and is what is did is cut an ecact size plug clamped it on one side and stitch welded my way around the hole. i over filled it and the grinded it down nicely. you cant even tell there was a hole there now. Ill get a pic when my wife tells me where the camera is..
Just did a TBI conversion and need some advice ghomer Engine 8 12-28-2006 07:16 PM
Used compressor checks - advice? BeeTX Garage - Tools 10 12-21-2006 01:52 PM
replacement pickup truck - your advice please jojo99 Hotrodding Basics 7 05-03-2006 10:52 PM
replacement pickup truck - your advice please jojo99 Engine 3 04-28-2006 04:48 PM
replacement pickup truck - your advice please jojo99 General Rodding Tech 6 04-28-2006 01:18 PM
