Pearls - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 01-22-2019, 07:48 PM
Pearls
Im restoring a 64 hard top chevelle,they want pearl over base,my question is,should i use a mid coat,or just put the pearl in clear,then use more clear over that??Thank u in advance for ur anwers!
Old 01-22-2019, 11:33 PM
39 master's Avatar
Pearls
I've done several pearls and they were three stage, but these were factory colors. First, the primer color will must be consistent over the whole body, then the base coat will also have a large effect of the final color, next is the pearl which needs to go on so that there are no "puddles" of pearl. Last is the clear. I'm no expert but have noticed everything must be consistent in order to have a one color paint job. Putting the pearl in the clear may work well. Real painters on here should answer.
Old 01-23-2019, 07:30 AM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
I say mid coat.
Old 01-23-2019, 09:08 AM
What I don't understand about your question is that putting pearl in the clear and then putting more clear over it it's STILL a "mid coat" three stage.
But the real "mid coat" is the way to go, you have more control. Do some test panels, then you will see.
Old 01-25-2019, 11:52 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
What type of pearl you using, a dry powder type?
If so, it usually gets mixed with a intercoat clear to
help keep the film build low.
That'll hold it till the clear coat.
Old 01-27-2019, 03:22 PM
Thanks guys,it is a dry pearl,im definitely gonna go with a standard mid coat,i did use it when layin flake,after trying to lay it in a clear,got much better results,the client was trying to get me to use clear for the pearl,so i just needed some input!
Old 03-03-2019, 02:09 PM
Easiest is to use the "mid coat" clear. It amounts to clear basecoat. I use a "cup gun" for pearls, I can drop a couple nuts in the cup to keep the pearl stirred up. My experience with gravity feed gun and dry pearl is the pearl falls out of suspension between coats, and spits out in clumps.
Question about HOK ice pearls.. beemdubya Body - Exterior 3 06-01-2005 02:05 PM
Metallics and pearls boofis Paint 2 03-19-2005 04:50 PM
pearls slug1000 Body - Exterior 8 12-15-2004 06:00 AM
Painting pearls and flakes Walk long objects? ChrisMiddleron Body - Exterior 3 02-15-2004 09:27 PM
pearls crazy larry Body - Exterior 6 02-10-2003 05:35 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
