Pfaff 545 Timing Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2016, 06:43 PM
I screwed up the timing on my machine. I got it fixed, however the seam is now biased towards the bottom, like the top thread is too loose or bobbin thread is too tight. I cranked a couple of turns more tension on the top thread, which didn't seem to change anything.
Is there anything I could have gotten wrong timing the machine that could cause this, and what would it be?
Thanks.
Old 10-03-2016, 07:16 AM
DanTwoLakes's Avatar
Wiki Edits: 22
No, the timing has nothing to do with the tension. Check the threading of the machine through the upper tension, and make sure the bobbin thread is under the flat tension spring on the side of the bobbin case.
Old 10-05-2016, 05:09 PM
Thanks, I will take a look at the routing and se if I can fix it with a tension adjustment.
pfaff, timing
Pfaff 545 service manual help... JJ269J Interior 25 08-10-2015 09:54 PM
Pfaff 545 Thread Problem Etester Interior 5 08-10-2015 08:12 AM
Pfaff 545 or 145 newbie... Igorsgonemadd Interior 2 08-01-2012 02:10 PM
Pfaff 545's worth ty0403 Interior 1 11-08-2010 04:08 PM
Advice on Pfaff 545 JJ269J Interior 13 10-02-2010 11:33 AM
