Picking aluminum heads for my 454 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-12-2018, 05:33 PM
Colin68's Avatar
well....that is very bad news. unraveling this is frustrating. Is it possible that the pistons in the car (whether they are stock dish, which I think may have been put in some of these blocks depending on the year) or whatever pistons they put in don't match the heads currently? Certainly what this seems to be coming down to is the pistons themselves. In the short run, if I can get it to stop smoking with some type of head solution, and maybe that means another set of rebuilt heads like the ones I have (I believe there is an issue with mine, as the mechanic that did the seals told me there were "ears"---whatever those are----broken off, which may be allowing oil to be pulled in to the cylinders), then I would be OK with it for a while. Ultimately, I want it to be RIGHT. While I am learning more about it, it is becoming more complicated. If this thing is smoking ONLY on deceleration and otherwise it runs fine, what would your gut tell you? Another note...when I pulled the valve cover off to check the number, there was quite a bit of oil pooling in the head.
  #17 (permalink)
Old 11-12-2018, 05:59 PM
ericnova72's Avatar
More for Less Racer
Heavy oil smoking on Decelů.first thing is does the valvecover got a good baffle where the PCV valve is??
Second thing would be intake to head gasket seal, sucking oil from lifter valley.
Valve seals and valveguides would be third seeing how you've said the seals are new. Even on worn guides, new seals should help, even if it is only for a few weeks, but you should be able to notice it helped or didn't.
I have no idea what your mechanic meant by "broken ears"....there really aren't any "ears" on BBC heads, so I don't know what his terminology is referring to.
Maybe the top upper intake bolt location at the divider wall between the intake ports on the heads is broken through into the port, or something like that??
A 454 with a flat top piston and 98cc head, using a .041" thick x 4.370" bore head gasket is just short of 9.0:1 compression....I don't think it will be a dome as I don't recall there ever being a closed chamber dome piston made for a 454(maybe the 1970 LS-6 solid lifter 450HP 454 is the exception), they were all open chamber engines. Aftermarket doesn't sell any closed chamber dome 454 pistons unless you order custom.
The flat tops and closed chamber trick is/was a rather common "magazine hack" for building up those flat top piston 454's without touching the assembled short block other than to change the cam......wouldn't surprise me to find out that's just what you've got.
You can get some pretty good low cost borescopes that connect to a smart phone on Ebay, that might be a simple way for you to see what piston you have without removing a head.
  #18 (permalink)
Old 11-12-2018, 06:19 PM
Colin68's Avatar
Ok...you are taking me to school here, which I very much appreciate. So...chances are I have flat tops...domes are pretty much not possible, and if they have been replaced, who would put dish pistons in it? I do not know if the baffle under the PCV is correct, or a problem, etc. Not sure how to tell that. The valve covers are aftermarket, but I suppose that doesn't mean much. The guy that installed my cam was good....I would be surprised if there is an issue with the intake gasket, but I suppose anything is possible. The guy that did the seals and mentioned the "ears"...Probably isn't going to see the car again. So you are leaning away from piston rings?
  #19 (permalink)
Old 11-12-2018, 06:47 PM
Check the torque on the intake manifold bolts, Weiand is now telling folks to retorque them every 6 months in their instructions. A quart in 90 miles is alot of oil.
  #20 (permalink)
Old 11-12-2018, 09:26 PM
ericnova72's Avatar
More for Less Racer
A vast majority of aftermarket valvecovers don't even have a baffle under the PCV hole, so check on that. No baffle and it will guzzle oil.
Better yet, tell us what valvecover you have and we'll look it up and see what it has.
Not using the correct type of gaskets for aluminum intake manifolds can lead to sucking oil also. The standard replacement Fel-Pro's for iron intakes often soon leak when used with aluminum intakes. Gasket doesn't have compression and rebound characteristics to match the higher expansion rate of aluminum . The intake gets hot, expands more, crushes the gasket beyond its rebound limit, and when everything cools back off it doesn't stay tightly sealed.
Any idea what intake gasket got used??
  #21 (permalink)
Old 11-13-2018, 04:53 AM
Colin68's Avatar
thanks for the reply! I did a little research this morning and found some info...the intake gasket # is an FEL 1210, and the valve covers appear to be Proform Parts 141813 (they were on the car when I got it).
  #22 (permalink)
Old 11-13-2018, 08:02 PM
ericnova72's Avatar
More for Less Racer
Okay, gasket is the right type. Covers look like they have a decent baffle, but you could road test by putting a breather in place of the PCV valve and then plug the hose gong to the carb, and see if your smoke situation clears up.
  #23 (permalink)
Old 11-14-2018, 08:25 AM
PHWOARchild's Avatar
Originally Posted by ericnova72 View Post
The bad news for you is that the stock 390 head casting is a closed chamber head, and that means only closed chamber pistons fit with it....and that means small domes at best, flat tops at worst.....and nobody in the aftermarket makes a closed chamber aluminum head.
Your compression ratio is going to take a hit, anywhere from a full 1 point drop to nearly 2-1/2 full points depending on what size open chamber aluminum head you were to use with closed chamber pistons.
The only two ways around that are: paying to have the heads angle milled right from the manufacturer or have a local shop do it, which is very likely to also require the intake manifold needing to be milled to fit the new milled heads....or you can replace the pistons and rings with a new set of pistons that have an open chamber sized dome.
My stock close chambered steel heads gives a CR of 10.25:1 and the pistons have a .182 high dome. I'm not going to mess with it too much. The combustion chambers are relatively small compared to an open chambered head.
049 corvette 454 heads vs new aluminum. KMPJ-93 Engine 6 12-09-2012 05:02 PM
Aluminum heads leaking on 454 skidderking Engine 23 11-28-2010 08:05 PM
aluminum manifold, aluminum heads, bolt torque william27103 Engine 8 11-07-2004 06:46 AM
help with a picking a tranny for my rat. Vryice Transmission - Rearend 1 04-13-2003 07:37 AM
picking a carb for my truck nitro junkie Engine 3 01-14-2003 09:10 AM
