Pictures of 1933, 3 pedal cars.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2020, 01:20 PM
31ROC's Avatar
Ok peeps, let's see some of those 3 pedal cars.....besides the obvious of removing my center console, I dont know how I'm gonna get clutch, brake, and gas pedals in this! Let alone, getting the brake pedal on the RIGHT side of the steering column! (See pic)
Old 02-13-2020, 07:17 PM
"180" Floor mounted clutch with the master under your foot or floor and a remote resivior. Pedal inline with steering shaft.
Old 02-14-2020, 05:27 AM
31ROC's Avatar
Any pictures?
Old 02-14-2020, 07:39 AM
Bob37pont's Avatar
Curmudgeon at Large
Speedway: https://www.speedwaymotors.com/TCI-6...bly,46285.html
Old 02-14-2020, 07:47 AM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
I used the Kugel 180 degree reverse mount behind dash brake/clutch pedal unit on my Willys. I also fabricated a new, smaller transmission tunnel out of fiberglass that allowed more room for the gas pedal. I have more information in my photo journal here:
https://www.hotrodders.com/forum/jou...ge=5&reverse=0
Take a look around entries #93 through #97 (viewed from most recent) where I document the installation.
I've also attached a few other construction photos below.
Hope this helps,
Steve
ID:	451853   Click image for larger version
ID:	451855   Click image for larger version
ID:	451857   Click image for larger version
The Following User Says Thank You to steve392 For This Useful Post:
lmsport (02-14-2020)
Old 02-14-2020, 08:45 AM
31ROC's Avatar
Hope this helps,
Steve
Great pics!
Are those tank/pedal assemblies bolted to that 1x1 frame or firewall? I ask because my car is glass, so firewall mounting is out. I didnt even see room for under floor!
Old 02-14-2020, 09:06 AM
123pugsy's Avatar
Purists Hate Me
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Rotated your pic:
Old 02-14-2020, 02:20 PM
I have a 5 speed in my steel '33 coupe, but I keep it at my summer home. I'll see if I can round up a picture from home here of the pedals in the chassis. I have the clutch on the left side of the column, brake and gas on the right, but I did custom build it all here. I'm using a modified original chassis. It's a tight fit, but it does work. My pedals come through the floor.
Old 02-14-2020, 03:02 PM
31ROC's Avatar
I CANNOT WAIT to see those!
Old 02-14-2020, 03:42 PM
Here's a few photos I had from the build. I used the original '33 pedals, rebushed them, bent the clutch pedal arm over under the floor, fabricated a custom mounting bracket and converted the clutch arm to use a GM hydraulic clutch set up. You can see some of the brackets in the frame shots if you look close. I also custom fabricated the trans tunnel, which may be somewhat narrower than yours. I've put over 100,000 kms on this car since then and the pedals have been flawless. Where the is a will.....there is a way. Good luck, Bill in Victoria, B.C.
Name:	Pedals related.jpg
The Following User Says Thank You to bill3337 For This Useful Post:
31ROC (02-14-2020)
Old 02-14-2020, 07:33 PM
I'm gonna have to check on what I'm smoking, I was expecting photos of 3 childrens pedal cars from the 1930's?
Imagine my surprise at the picture? A WTF moment if there ever was one, but after a day of harsh words from the old lady, it was fun to laugh at myself.
Thanks, Bogie
The Following 3 Users Say Thank You to BogiesAnnex1 For This Useful Post:
123pugsy (02-14-2020), 31ROC (02-14-2020), Bob37pont (02-15-2020)
Old 02-14-2020, 08:12 PM
Looking back on my photos, it looks like I bent the brake pedal arm as well. It's been over 20 years since I finished this car. Just finished another one for my wife this fall..37 Slantback.
Old 02-15-2020, 07:57 AM
steve392's Avatar
just passin' thru
Wiki Edits: 2
Great pics!
The pedal frame assembly is bolted top and bottom to the 1x1 frame. The frame in turn is bolted to the reinforced fiberglass body and firewall. I epoxied and fiberglassed plywood reinforcing onto both the body and firewall near the cowl area and incorporated threaded studs into the wood which the 1x1 frame bolts to. I also bonded the bottom horizontal bar of the frame directly to the fiberglass firewall to further stiffen everything up. A few earlier entries in my photo journal document that part of the installation.
I also reinforced the Kugel pedal frame itself by welding 3/4 inch angle around the bottom perimeter of the frame to stiffen it up. I've included a few more photos. Take a look at the bottom of the frame where it is clamped between the vise jaws. You'll see the other welded-in reinforcement. The other photo shows how the whole pedal assembly is bolted to the frame.
ID:	451875   Click image for larger version
Old 02-15-2020, 10:10 AM
31ROC's Avatar
Looks involved for a rookie like myself. Guess a winter project for next winter....
Thanks again!
Old 02-15-2020, 10:59 AM
fat tire's Avatar
fat tire
Thanks, Bogie
you are not the only one
