Piston Damage - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 04-13-2015, 08:18 PM
Interesting. Good to know. I guess the KB hypers got me thinking other would be weird as well. There was more to em than I thought there'd be when I originally got them.
  #47 (permalink)
Old 04-14-2015, 05:13 PM
Jahblah90's Avatar
Delta Alpha Tango Juliet
UPDATE!!!!!!!! Okay, got of work today with enough time to make a mad dash for the auto performance shop. I took some of my "mess" to be analyzed for my rebuild basis. The pistons are dome 12cc and are standard bore. The rods are 5.7 standard rods. The crank is from a SBC 400. So I guess I have a 377??? THAT WHORE!!!!! lol smh well, I don't know much about 377's but I WANT my 383 so I guess I will get a .030 over bore. So far, I'm leaning toward hyper dished pistons for my rebuild. At least a 12cc dish and 64cc aluminum heads. AND SO IT BEGINS!!!!!!!!!!!!!!.............SMH
  #48 (permalink)
Old 04-15-2015, 05:24 AM
64nailhead's Avatar
Chevy Bore and Stroke Data
Take a look, Your 400 crank is either a 400 or 383. If the bore is 4.0-4.030, then it's a 383, not a 377.
I'm glad to see you have taken it to a machine shop (reputable hopefully). I can't remember or can't find it in this thread, but as several others have mentioned putting money into stock rods and stock heads is good money on top of bad if this is going to be even a mild performance build; also it's not cheaper. If it's a daily driver sub 4500-5000 rpm's then use the stock parts.
My two cents and best of luck to you - Jim
  #49 (permalink)
Old 04-15-2015, 01:48 PM
Cars, Trucks, Boats
. It's the '383' design plan... but at standard bore, it's 377"... not much difference... the usual .030" overbore is just to clean up a used bore block and produce something like a brand new engine...
. The crank and rods are fine for the low compression street re-build planned... the standard cast pistons were the scariest part... go for some KB hypereutectic pistons...
. Did you get a measurement on cam lift? ... Or brand name/grind number?
  #50 (permalink)
Old 04-15-2015, 03:23 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
If those are production 5.7" Chevy rods, then the builder must have used a cam with reduced diameter base circle. Stock rods in a 383 will hit some of the cam lobes, so you can either replace the rods with units that will clear (such as the Scat #25700P) and use full-size cam lobe circle or use a reduced lobe circle cam if you are going to use 5.7" production rods.
I'm going to give you some advice.....
1. Do not buy ANY parts of ANY kind until you have a complete engine build plan written down on paper that everyone on this board has read and approved.
I learned a long time ago not to buy a pig in a poke and hopefully you have just learned that lesson also. Never buy a complete motor that you have not seen inside of. Much cheaper and smarter to buy individual parts and pieces at current market value and engineer the build yourself with help from fellows like the ones on this forum.
If you're going to use aluminum heads, they will allow a max static compression ratio of about 10.5:1 on pump gas. More SCR than that could get the motor into detonation, and you've already seen the results of that. You don't have to build the motor at 10.5:1 though, you can build it at mostly anywhere between 9.0:1 and 10.5:1, depending on the camshaft characteristics you are looking for. For instance, a 9.0:1 to 9.5:1 build would allow the use of a mild camshaft, resulting in good street performance with good fuel mileage and good manifold vacuum for decent fuel mileage and for operating power brakes and other vacuum-operated accessories. The wilder you go with the cam timing, the more concessions you will have to make and the steeper gears you will need in the differential, because the cam will be operating in a higher range of rpms and so will require stiffer gears.
When planning a build, begin with your stack of parts. Add the piston compression height, the rod center to center length and the radius of the stroke together and find the STACK. For instance, you might use a 1.425" piston compression height, 5.7" rod length and 1.875" crank radius to arrive at a stack of 9.000". Or you might prefer a longer rod, using a 1.125" piston compression height, 6.0" rod length and 1.875" crank radius to arrive at a stack of 9.000". Here's the rod I would use if I were going to build a long-rod motor, it is clearanced to miss the cam lobes of a standard base circle camshaft....
http://www.summitracing.com/parts/sc...make/chevrolet
Oftentimes, beginning with a new set of quality rods that are ready to use will be cheaper than re-conditioning production Chevy rods, particularly if you add magnaflux to find cracks and quality aftermarket rod bolts and nuts. Then you still have to address the clearance problems at the cam.
Now, you have a stack of 9.000" that you need to fit into the block, with the proper piston deck height to allow the use of a composition gasket and still engineer the squish to 0.035" to 0.045".
Airflow Research recommends a Fel-Pro 1003 composition head gasket with their aluminum heads, so that is what I would go with, no matter whose aluminum heads I used. The bore is 4.166" and it compresses to 0.041". If you use steel shim head gaskets with aluminum heads, the differential in movement between the iron block and the aluminum heads will cause the heads to move around. If you use a steel shim head gasket, there will be insufficient "cushion" to absorb the movement and the heads will suffer fretting, wearing away of the head surface because of the relative softness of the aluminum against a relatively different-moving steel gasket.
I like to recommend a very tight 0.035" squish on a SBC, so in this case, with a 9.000" stack, I would cut the block decks to a new block deck height of 8.994" after having the machine shop verify that the main saddle bores are all round and parallel with each other. Get the mains dialed in first, that's the foundation of the motor, then cut the decks. The stack of 9.000" and the block deck height of 8.994" will allow the piston crowns to "pop-up" out of the bore by 0.006", allowing a squish of 0.035" with the 0.041" thickness of the composition head gasket.
Such a motor, with 64cc heads and 12cc pistons, would exhibit a 10.34:1 static compression ratio. With the aluminum heads and using a 0.035" squish as outlined above, this motor should run very well without detonation on pump gas. A cam with 0.050" duration of 227 to 230 on the intake side would be a good choice.
Moving to an 18cc piston would allow a 9.72:1 static compression ratio, allowing you to use a milder cam for a more street-friendly operation. A cam with a 0.050" duration of 214-216 on the intake side would be a good choice.
Using an 18cc piston with 70cc chambers would make 9.17:1 static compression ratio, which would like a cam with a 0.050" duration of 204-206 on the intake side.
Here's where I'm getting the cam ranges from. I put this tutorial together after thoroughly investigating the recommendations of Crane Cams engineers.....
http://www.crankshaftcoalition.com/w..._compatibility
A dual-plane, high-rise intake manifold such as the Edelbrock Performer RPM (not the Air Gap model) will make more hp and torque (power under curve) in a street motor than any other manifold you could bolt onto the motor. I don't like the Air Gap model, even though it will make a few more hp than the standard RPM. The open gap on it will not allow heating of the air/fuel charge in cool or cold weather and can contribute to driveability problems. If you're going drag racing and want an extra couple of hp, use the Air Gap. If you're building a street motor where driveability needs to be addressed, use the standard RPM.
The RPM, together with the Weiand Stealth 8016 and the Holley Street Dominator 300-36, were copied from a design that Chevrolet produced for the 1968 Camaro 302 Z-28 motor and farmed out to Winters Foundry to be cast in aluminum. The 8016 and 300-36 have been discontinued from current production, but can be found used on craigslist, racing junk and local swap meets. Another current production manifold that will work well is the Weiand 8150.
An 850 carb would make the most power on a 383, but may be overkill on a street motor. A 750 with vacuum secondaries might be my choice for such a motor, along with a good set of 1 3/4" long-tube headers. Choose only headers with a flange thickness of 3/8" to help prevent the flange from curling up like a potato chip from the heat of operation and spitting out the exhaust gaskets. Install an H or X pipe immediately after the collectors to equalize flow from each side of the motor and sweeten the exhaust note. Actually, a Rochester Quadrajet would be my carburetor of choice on any street motor. It would require a spread-bore intake manifold such as the Edelbrock RPM #7104. If using a Quadrajet interests you, get your hands on Cliff Ruggles book and learn how to rebuild and tune them.....
http://www.cliffshighperformance.com/
There now, your turn....
The Following 2 Users Say Thank You to techinspector1 For This Useful Post:
123pugsy (04-15-2015), Jahblah90 (04-15-2015)
  #51 (permalink)
Old 04-15-2015, 05:06 PM
123pugsy's Avatar
Purists Hate Me
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Cliffs High Performance Quadrajets :: Qjet Carburetor Rebuild Kits, Parts, Quadrajet Rebuilding, Quadrajet Parts, Bushing Kits, Carb Tuning
Excellent post Richard.
Thank you.
The Following User Says Thank You to 123pugsy For This Useful Post:
techinspector1 (04-15-2015)
  #52 (permalink)
Old 04-15-2015, 06:19 PM
Jahblah90's Avatar
LOL you can breath now! That is a bonafied WHOPPING of good info! I learned a lot too. So I shall go with 18cc dish pistons and 6" rods. I like your projected static compression ratio a lot better, and if plans need adjustments, I could just rethink gasket thickness to compensate instead of pistons or head chambers. I really did want to use the Air Gap because i've always wanted to try it and it had a few more HP over the RPM but I'm not willing to sacrifice that much driveability seeing is how this will be an 80% street car. And judging by your link, i'm going to need a better idea of my compression ratio before a camshaft is determined. I never truly got a good understanding of camshafts so that helped. I want to either go retro-roller camshaft (pretty pricey) or get my block's oil galley drilled and tapped for the dog bone lifter retainer. Flat tappets are cheap but cheap doesn't always equal good. I'm only 24 but i'm slowly building hotrodders wisdom lol I will DEFINITELY run my build sheet by YOU good sir! You took the time out to type this extremely informative post and I honestly do appreciate it. Thank you!
  #53 (permalink)
Old 04-15-2015, 06:44 PM
64nailhead's Avatar
L I like your projected static compression ratio a lot better, and if plans need adjustments, I could just rethink gasket thickness to compensate instead of pistons or head chambers.
NO, NO, NO.
Proper squish/quench is 'engineered' into the motor. Changing it via a head gasket thickness change is silly and detrimental to your end goal. As Tech said, don't buy a part until you have laid out on paper everything you'll be purchasing. Also, inorder to change the compression via head gasket thickness is going to be such a minute change that it isn't worth wrecking a proper squish/quench set up. You change compression via different piston or head volume which implies you need to buy the right parts up front.
  #54 (permalink)
Old 04-15-2015, 08:23 PM
Wiki Edits: 326
Originally Posted by 64nailhead View Post
NO, NO, NO.
Exactly what I would have said to the OP. Thanks 64nailhead.
Also, the OP would be on a fool's errand to try to convert a flat tappet block to an OEM-style roller cam. Either begin the build with a factory roller block or use the retro-fit components when converting an early block to rollers. Expense is relative, you only have to frag one flat tappet cam, then have to remove the motor and tear it down completely to remove all the shrapnel to find out that there is a better way with a retro-roller in the first place. Howards has SBC cam and lifter kits for under 600 bucks.
Please read through this tutorial to find out why it's foolish to run a flat tappet cam today....
http://www.crankshaftcoalition.com/w...ips_and_tricks
  #55 (permalink)
Old 04-15-2015, 09:18 PM
Cars, Trucks, Boats
UPDATE!!!!!!!! The rods are 5.7 standard rods. The crank is from a SBC 400.
. Are you sure the machinist said the rods are standard 5.7" rods from a 350 or smaller? And not standard 5.565" rods from a 400...???
  #56 (permalink)
Old 04-25-2015, 12:38 PM
Jahblah90's Avatar
This is why I made the previous statement about drill and tapping my block.
https://www.youtube.com/watch?v=AgxFIPJGY80
Apparently it has been done successfully throughout the hotrodding world. This method seems a lot cheaper but I did not want to take the chance and screw my block up so I HAVE PURCHASED A RETRO-FIT LIFTERS SET. I figured I would buy piece by piece. Yes, buying all the parts in a bundle would be cheaper but my wife won't overlook $700+ out the door LOL she would go ballistic!
  #57 (permalink)
Old 04-25-2015, 12:42 PM
Jahblah90's Avatar
I could have sworn he said 5.7 but i'm pretty sure he said standard. Crank is a 400 so maybe he meant standard for the 400 like you said.
  #58 (permalink)
Old 04-25-2015, 04:07 PM
Cars, Trucks, Boats
. That video about converting the 400 block to EOM roller lifter setup so can use the lighter OEM roller lifters was interesting... but I didn't catch why he used the special V6 lifters instead of the regular V8/V6 lifters... is it in there somewhere? I may try that on my 400 block... not sure if I'll put that in my '87 GTA or just hop up the TPI 350...
  #59 (permalink)
Old 04-25-2015, 06:19 PM
ericnova72's Avatar
More for Less Racer
The 60 V6 lifter is shorter than the V8 hydro roller lifter, the shorter lifter must be used because the lifter bore casting in the block is shorter than it is for '86-up roller lifter blocks. The dogbones won't fit right if the taller V8 roller lifters are used on an earlier flat tappet block.
This info is also down in the comments section below the video.
The Following User Says Thank You to ericnova72 For This Useful Post:
BuzzLOL (04-25-2015)
  #60 (permalink)
Old 04-25-2015, 06:30 PM
Cars, Trucks, Boats
. Thanks, Eric... I presume those lifters are even lighter yet... maybe about like a flat tappet hydraulic lifter...
383, damaged, piston
Piston ring damage coldfreshwater Engine 4 12-16-2012 07:53 PM
Acceptable Piston Damage? possibly dropped...? dumbmechanic Engine 4 11-17-2010 12:08 AM
Blower motor blowby and piston damage 68NovaSS Engine 15 08-27-2009 07:40 AM
Old TRW Piston Part # 234-98 396 Chevy Forged Piston? heathj1 Engine 1 07-21-2009 06:14 PM
Piston Skirt Damage: Consequences? Petea216 Engine 14 04-20-2007 05:48 PM
