piston ring compressor recommendation - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2008, 09:51 AM
GMR GMR is offline
Would like to know which you like regardless of price. Please identify the type and manufacturer. My old Craftsman ratcheting spring steel style just gave up the ghost.
Old 10-26-2008, 12:25 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Moving to engine where the engine builders can weigh in,,
Sam
Old 10-26-2008, 01:03 PM
OHD's Avatar
OHD OHD is offline
ARP and many others make single size tapered sleeve, ring compressors.
Old 10-26-2008, 01:08 PM
327NUT's Avatar
I still use my old ratcheting type ring comp.....had it for a long time and it works great. Granted, they take a little more time to use but I'm never in a big hurry when installing pistons. If I had a shop and time meant money then I would probably get a set of the newer non-adjustable alum. ones.
Old 10-26-2008, 01:55 PM
Last journal entry: More on the Cobra Engine
I'm also partial to the tapered sleeve ring compressor. They are expensive if you do several different sizes of pistons, but they offer the best piston ring compression when installing pistons. I have used the old, sear band clamps like you had, and they will get the job done, but on serious engine builds I'm partial to the tapered sleeve, no ring problems and the pistons go in very smoothly and fast.
Old 10-26-2008, 03:02 PM
Paul Marion
Last journal entry: 1935 Plymouth Pj coupe
Piston ring compressor rec'
(ARP and many others make single size tapered sleeve, ring compressors).
These are the best compressors period. Unfortunately for people like me, I'm always building different mfg's in numerous bores sizes. So I end up grabbing the trusty (adjustable) band type. Hell; the most important parts in this assy process are the lil'/pcs of rubber hose applied to the ends of the rods, to keep from "nicking" the crank journals.
Old 10-26-2008, 03:39 PM
I like the "FREE loaner" available at Autozone.....
(it's a regular spring steel ratchet wind up type)
hard to beat that price!!!
Old 10-26-2008, 03:46 PM
I have the Childs & Albert tapered compressors for most engines I build (4.500" 4.5030" 4.0560" and 4.625") and love them but for the ones I don't have I have the Snap On set with the band and pliers that hold the band tight. The second choice is a KD brand with a corrigated band and adjustable over center lock. They are blue spring steel with a red handle, and will do up to a 4.600 bore piston.
Old 10-26-2008, 06:17 PM
GMR GMR is offline
great, thanks all
Old 10-26-2008, 07:10 PM
GMC boogie's Avatar
This is what I use
http://www.lislecorp.com/tool_detail.cfm?detail=241
It works very well for me and can be used on many different bore sizes.
Old 10-27-2008, 08:35 AM
GMR GMR is offline
another one to check out, thanks GMC
Old 10-27-2008, 09:35 AM
engineczar's Avatar
If your going to do alot of work with Small Block Chevies, Mopars, or Fords with displacements around 340/350/351 then these work pretty good. The 4.00-4.09 range covers quite a bit.
http://www.competitionproducts.com/p...p?number=08970
BSE Racing Engines
Old 10-27-2008, 01:15 PM
I really like the one I use from Goodson.
http://www.goodson.com/store/templat...1b633a7bbfa8ba
Old 10-27-2008, 03:03 PM
406 ss monte's Avatar
eat a beaver, save a tree
i have these too & like them. i also have one like gmc boogie has too, i just haven't had a chance to use it yet. i've heard good things about it though.
Old 10-27-2008, 03:07 PM
I've tried just about every one out there in my worklife, including the Lisle and the tapered ring. The tapered are the easiest but unless you want to have a whole collection, the best one I've found is the goodson type.
stroke to rod ratio jacobm99 Engine 28 12-16-2013 05:46 PM
Busted a bloody piston ring!!! flynbrian48 Engine 8 02-14-2008 09:28 AM
Piston ring Question (For Nitrous) Ratoflic Engine 0 04-19-2006 04:04 PM
327 in 88 Truck pete379 Engine 100 01-19-2006 08:20 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 10:06 AM
