Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Plastic, ABS repair- fan shroud
Old 08-17-2016, 12:34 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Originally Posted by ntfday View Post
Another option would be to fabricate one from sheet aluminum.
That's what I would do, just build a an aluminum box from sheet, held together with pop rivets and a hole cut out of the back of it to fit half the depth of the fan blade(s) into. Do you have any friends with a sheet metal brake? If not, a HVAC shop in your town will be able to bend up the pieces for you for cheap.
