plastic box what is it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2017, 12:35 PM
bsa_bob2's Avatar
On my 'Portaband Saw is this plastic box -wrapped in a little brown- stiff hard cover. The hot wires come in one end and ==out the top end as you can see. I wish to eliminate this plastic box..to mount a switch in its ---spot.Not sure what it is. might not work and ruin whats left of my old Portaband anY help appreciated bob s
Name:	PORTABAND SWITCH 001.jpg
ID:	378857   Click image for larger version
Name:	PORTABAND SWITCH 003.jpg
Old 09-23-2017, 01:21 PM
36 sedan's Avatar
That is the switch, it is activated by the trigger. That particular switch is no longer available, but you may be able to get something close from the link below. Use the measurements they provide at bottom of page to determine which one is the best replacement fit.
POWER TOOL SWITCH 8307K1 with lock
Old 09-23-2017, 01:34 PM
Like was said the brown paper is insulation for the switch [plastic box] this switch controls both the power AND the neutral [safety thing] you COULD just pair the neutrals[white wires & switch the power [colored leads]
Old 09-23-2017, 03:24 PM
bsa_bob2's Avatar
Wow!! I knew if i kept at it- i would come across some options.I am going to measure and order that switch Monday morning 36 sedan- and thank you . If it turns out wrong i will mount a switch ,haven't decided the best place for this to be attached, so i could hit a toggle switch quickly, anyone ever do this ??????
ps This switch you refer me too looks like its a twin brother to my bad one.
thank you both very much bob s
Old 09-23-2017, 05:59 PM
36 sedan's Avatar
Power tools of this nature almost always switch both power and neutral, as it is very unlikely both set of contacts weld themselves keeping the tool on (safety).
If you need to use an alternate switch type (toggle or other), I would recommend you continue with the dual contact set (D.P.S.T.) type switch.
Old 09-23-2017, 06:11 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
I would lie to see what is inside of the brown wrapper. Could it have a small capacitor?
Fact is stranger than Fiction
Old 09-24-2017, 08:42 AM
S10xGN's Avatar
Gotta love a turbo!
Or a variable speed resistor...
Russ
Old 09-24-2017, 08:58 AM
bsa_bob2's Avatar
just little plastic box which i think i have found A replacement switchon the link above looks like mine enough to buy it for 11.00 try it and see. Toggle switches are going to be hard to mount- and hang on to the saw properly .As i appears. bob s
Old 09-24-2017, 09:01 AM
bsa_bob2's Avatar
Russ
Variable resistor would be for "slower speeds: when its cutting steel--wouldn't it this Portaband runs one speed- whenever its got power shoved to it
Old 09-24-2017, 09:02 AM
bsa_bob2's Avatar
When i get it out i'll take it apart ~and see what it is.post it here. bob s
Old 09-24-2017, 09:05 AM
bsa_bob2's Avatar
D.P.S.T. Whats this stand for please 36 sedan. btw Do you have any extra parts for A35 sedan. My friend bounced his of a guard rail this summer early Has had it back on the rd for lack of parts. thank you bob s
Old 09-24-2017, 10:47 AM
36 sedan's Avatar
D.P.S.T. = Double, Pole, Single, Throw. Meaning the switch has 2 sets of contacts with one position ON/OFF.
D.P.D.T. = Double, Pole, Double, Throw. Meaning the switch has 2 sets of contacts with two positions ON/OFF, OFF/ON.
Sorry, currently I have very few extra parts.
The Following User Says Thank You to 36 sedan For This Useful Post:
bsa_bob2 (09-24-2017)
Old 09-24-2017, 12:07 PM
bsa_bob2's Avatar
Originally Posted by bsa_bob2 View Post
D.P.S.T. Whats this stand for please 36 sedan. btw Do you have any extra parts for a 36 ford sedan. My friend bounced his of a guard rail this summer early Has had it back on the rd for lack of parts. thank you bob s
There i got it right!
How about a $2500 plastic fuse box? MARTINSR Hotrodders' Lounge 12 08-17-2011 12:48 AM
steering gear box 55 chevy(manual box) 55 Bullit Suspension - Brakes - Steering 3 11-21-2010 02:35 PM
Vega Box or Reverse Corvair Box? Ltlgto Suspension - Brakes - Steering 9 04-24-2008 06:02 PM
ford/chevy box new box demetions? 56-Dodge Body - Exterior 2 01-01-2004 10:06 AM
HELP 1959 chevy box swap to newer box style big jer Body - Exterior 1 10-07-2002 01:37 PM
