Hot Rod Forum : Hotrodders Bulletin Board (https://www.hotrodders.com/forum/)
-   Engine (https://www.hotrodders.com/forum/engine/)
-   -   Please help an old guy working on a new(ish) Chevy V8 (https://www.hotrodders.com/forum/please-help-old-guy-working-new-ish-chevy-v8-149535.html)
johnnya 12-10-2008 05:20 PM
I'm helping a kid from work (anyone under 50 is a kid to me) replace his throttle body, Vortec 5.7 litre engine in a '98 Chevy 1/2 ton pick-up, with a GM Performance crate engine.
My question is: do you still set the timing in the normal way, with a timing light, or is there some kind of magic I'm not aware of?
Thanks in advance :)
JA
ap72 12-10-2008 06:55 PM
you have to disable the electronic advance on the dizzy, I'm not sure how to do it on a '98 pickup but I'm sure someone will chime in.
GMC boogie 12-10-2008 07:16 PM
Of course the distributor needs to be installed correctly but no,you do not set the timing,it is controled by the computer. However,the cam sensor(in the distributor) needs to be phased with the crank sensor. This is done by adjusting the distributor with a Tech 2 scan tool hooked up. You will have a check engine light on if it is not correctly phased....I forget the code #. P1345 maybe?
All the ones I have fooled with required the distributor to be rotated all the way counterclockwise to make the light go out.
johnnya 12-10-2008 08:12 PM
I stabbed the distributor today with my normal method. IE: I turned the crank in the normal direction, while watching the valves to determine the firing stroke on #1 cyl, and stopped the crank at about 6 degrees before TDC. I then stabbed the distributor with the rotor pointed at the #1 cyl contact. Should it start like that?
GMC boogie 12-10-2008 08:42 PM
Yes, distributor drops in same as years before. Your good to go as long as you know your at the #1 firing position.
carsavvycook 12-10-2008 09:36 PM
The distributor is referred to as the "cam sensor". The scan tool needs to have the capability to read the "cam sensor" 'set' degrees. This is set to 0 degrees. Each movement of the distributor requires the engine to be revved over 2000 rpm, and allowed to return to idle before turning it again. It can be adjusted within +1 to 2, or -1 to 2 degrees of the crank timing at TDC, without turning on the CEL. They like it best overall to be at 0 degrees with the crankshaft at TDC.
It should fire off if you have it real close, but the check engine light will turn on, if it is not close enough to 0 degrees sync with the crank sensor #1 cylinder TDC compression signal.
johnnya 12-11-2008 07:23 AM
Thanks for thr replies, guys.
Looks like the first trip will be to a shop with the proper tools to set the distributor.
Nothing newer than a '74 for me after this. :D
JA
tnovot 12-11-2008 07:18 PM
JA
My 75 Corvette has no computer which is one reason I sold my '84 and shopped around for an older one.
I think GM didn't start using computer controls until '81 or '82 so you could still go a few years newer than '74.
Terry
ap72 12-11-2008 07:30 PM
yea, but you still have the CLA to tend with... I would prefer to stop at '72.
Rob Keller 12-11-2008 07:50 PM
johnnya
So ,you was a Complete adult @ 13?
Sorry I just could not resist.
In my opinion its better to be a smart arse than a dumb arse. :thumbup:
I dislike computer cars too.
Puters are our freinds :smash:
:D
R :thumbup:
johnnya 12-11-2008 08:15 PM
Rob Keller said:
"So ,you was a Complete adult @ 13?"
I'm not even sure I'm a complete adult, now... ;)
JA
