power brake vacuum - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2018, 02:04 PM
power brake vacuum
hi i have a flathead and want to use power brakes do you think i will have enough vacuum to operate the booster? and where is the best source to get the vacuum from the intake has two strombergs on it. i seen posts on here that refer to a pump that helps but not in detail how and if it works?? any thoughts?
Old 07-18-2018, 02:19 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Generation of enough vacuum to operate power brakes is dependent on the camshaft duration and lobe separation angle. A stock or mild grind flathead cam should easily drive a booster, regardless of the number of carburetors attached to the intake manifold. If there is no vacuum port drilled and tapped into the intake manifold, I would use a carb spacer under the primary carb (on a 3-carb system) and drill and tap the spacer for vacuum. With a 2-carb system, I would use spacers under both carbs just to keep the eyeball correct, then drill and tap just one of them for vacuum, probably the rear one.
Old 07-21-2018, 08:50 PM
yes but theres the window wipers that take vac also i just dont want to starv the motor of vac
Old 07-22-2018, 11:14 AM
'49 Ford Coupe's Avatar
1949 Ford Coupe RESURRECTION
This works :
https://49fordcoupe.smugmug.com/Addi...-Power-Brakes/
Old 07-22-2018, 02:37 PM
and i can find all this on amazon ???
Old 07-22-2018, 03:04 PM
Yup...
You can get the vacuum canister from a junk yard.. sand it a little bit, spray paint with plastic rated paint, OH I JUST REMEMBERED !.. .I drilled out the canister tube connector and tapped the plastic for a brass fitting, cause the connector was tiny.. thought it better to put a 1/4" brass threaded nipple in there ...
https://www.amazon.com/Superior-Univ...Y13F6Q2E6KAET9
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The Following User Says Thank You to '49 Ford Coupe For This Useful Post:
4ford (07-23-2018)
Old 07-22-2018, 10:45 PM
Neither the wipers nor power brakes need much air. It is the amount of vacume that is important. With a mild cam you should be fine. The wipers have issues at high throttle because vacume drops. The prakes are not used at full throttle but with accelerator released. They will receive full vacume and should work fine.
John
The Following User Says Thank You to John long For This Useful Post:
4ford (07-23-2018)
power brake vacuum bill plise Engine 1 02-05-2017 03:47 PM
Power! -- No power? -- Power!!!! No Power???! Fragzem Engine 10 05-16-2005 02:30 PM
power brake booster vacuum canister?? Ed ke6bnl Suspension - Brakes - Steering 1 10-21-2004 05:33 PM
power brake vacuum low DaveForddriver Suspension - Brakes - Steering 5 10-11-2004 06:55 AM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 03:25 PM
