Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power brakes for 57 Fairlane
Old 09-30-2018, 02:18 PM
JeffB28 JeffB28 is offline
You will need one like this that has the offset bracket to clear the Y-block https://www.ebay.com/itm/1957-1959-F...YAAOSweW5U3n1A This also has the dual diaphragm booster Also if you still have drum brakes all around you will need the 10 lb residual valves listed.
The Following User Says Thank You to JeffB28 For This Useful Post:
techinspector1 (09-30-2018)
