Power brakes for 57 Fairlane - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2018, 12:47 PM
Anyone convert 1957 Fairlane with stock 312 to power brakes from manual? Some power masters say "not compatible" with stock 312...any suggestions?
Thanks.....LB
Old 09-30-2018, 01:49 PM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
powr brakes
My 58 Fairlane convertible 352 came stock with power brakes. Same body, should just need the vacuum hose hooked to the intake. I didn't like mine because of the slow release. For drag racing I bypassed the booster.
Old 09-30-2018, 03:18 PM
You will need one like this that has the offset bracket to clear the Y-block https://www.ebay.com/itm/1957-1959-F...YAAOSweW5U3n1A This also has the dual diaphragm booster Also if you still have drum brakes all around you will need the 10 lb residual valves listed.
The Following User Says Thank You to JeffB28 For This Useful Post:
techinspector1 (09-30-2018)
57 ford fairlane with power rack... h8louzn Suspension - Brakes - Steering 9 12-21-2006 09:09 PM
Anyone put a 302/5.0 into a 57 Fairlane? MM in NM Engine 24 11-04-2005 07:04 PM
Tube Chassis For A 57 Fairlane Lou Suspension - Brakes - Steering 5 08-21-2005 09:45 PM
frame stub for 57 fairlane CHRIS57FAIRLANE Suspension - Brakes - Steering 2 07-29-2005 12:34 PM
302 into 57 fairlane lennybeets Engine 4 09-10-2002 04:51 PM
