Power Steering issue(s) - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2018, 03:38 AM
64nailhead's Avatar
I've been experiencing minor binding at low rpm's. And intermittently it gets 'stuck' at initial startup. This issue has been getting progressively worse for the past couple of weeks.
I'm running a stock GM steer gear for a G-body with a type 2 pump. I changed reservoirs to an attractive looking one that doesn't have a vent (??). I had a stock reservoir off from a Saab that was grafted into a mount that had worked quite well. At the same time I changed the reservoir I installed a new pump due to the old one had began leaking minorly at the front seal.
The fluid seems to get too hot. I can't touch reservoir after it's been running. I haven't checked it with a heat gun, but the previous reservoir didn't get that hot. I'm not running a cooler, but i could try one. I installed a flow restrictor on the pressure port because when I look in the reservoir the fluid seemed to be flowing at an extreme rate. Also it's getting aerated.
I think (repeat think) the aeration is the bulk of the issue which makes me think I need a bigger and/or better designed reservoir, but the lack of cooler and no vent have me concerned as well. At driving speeds the steering is completely normal.
What temps should I be seeing? Do I have to have a vent?
Old 10-02-2018, 10:46 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Sounds like the box is bad.
I wouldn't worry about the fluid movement for now.
Old 10-02-2018, 03:38 PM
64nailhead's Avatar
What makes you think that? I have to say that the steer box(gear) is directly out of the junkyard 3 years ago and I'm not opposed to replacing it - AT ALL lol.
Old 10-02-2018, 08:15 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
[ I installed a flow restrictor on the pressure port because when I look in the reservoir the fluid seemed to be flowing at an extreme rate.] Quote
Fluid is being bypassed inside pump reservoir as it is not being used to move the steering gear. It is normal. Heat is generated in this process. Reducing the flow is best done by using a type 2 pump. Flow is decreased by the use of a thinner pump rotor and vanes . (.400 thinner than a P type pump ) , Thinner rotor /vane pack gives less volume than (same diameter) P type pump
That alone cuts parasitic drag and heat generated in the fluid bypass inside the pump body
The Flow restrictor is causing the added heat. You dont need it. Probably is the root cause of your intermittent assist problem ie: binding? hard to turn?
If aeration is a problem the pump will whine. A worn pump, or a front seal,leaking fluid out (and air in BTW) can cause whine. Low fluid (of course) does as well.
PS coolers are a good idea.
The type 2 pump was a good move, if it has the volume needed to run a G body box (it does)
They use the type 2 on grand cherokee, which has the quick ratio box that is so desired (And currently running in my 64)
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
64nailhead (10-02-2018)
Old 10-02-2018, 08:41 PM
64nailhead's Avatar
LATECH,
I understand what you're describing about the flow restrictor. Do you think the non vented system and lack of reservoir baffle are an issue? I ask as I ran this without the restrictor when I installed the second reservoir and the aeration and pressure in the reservoir was astounding.
I can reinstall the original pressure fitting in minutes to test, but I believe that I need to lose some of the aeration.
What year Grand Cherokee is the quick ratio gear found in?
Old 10-02-2018, 09:01 PM
LATECH's Avatar
12.7 to 1 is in the 94-98 Grand cherokee
May be more, but those years for sure
The GC runs the type 2 pump so it should be a win win
I have a P style on my GTO with the quik ratio .Works well.
Old 10-02-2018, 09:07 PM
LATECH's Avatar
Originally Posted by 64nailhead View Post
LATECH,
Old pump was probably worn down. Restrictor may (probably) be the cause of heat/aeration. It is causing to much pressure against the pump internal bypass
Use ATF also.It resists foaming better than PS fluid
Old 10-03-2018, 01:10 PM
Sounds like the internal servo is worn and bound up. I would believe it even more if it were during cold fluid condition, as before it heats up and aerates.
Old 10-22-2018, 05:16 PM
64nailhead's Avatar
I'm waiting for a part so I did some additional testing and thinking - and sometimes the thinking is slow - lol! I ordered a new pressure hose so that I can put the original discharge fitting back into the pump. The reason being that the restrictor fitting requires an AN hose as opposed to the stock flared o-ring so I modified my original hose.
With the engine off I put it on some bags (friction helpers) and it seems to turn normally - maybe a little sticky at first movement, but I think it's fine. Now I have it in the air with jack stands under the a-arms next to the ball joint. It turns effortlessly via hands on the tire and on the steering wheel. When I start it up, it actually turns harder than when the motor is running????
I'm sticking with the plan to swap out the restrictor and re-test. But I have a question about the fluid - is it going to hurt anything using motor oil? I try not to doubt someone that I'm asking for advice, but I've read that the ATF in the system is harmful to the seals. Is that hogwash or what???
Old 10-22-2018, 06:09 PM
39 master's Avatar
Power steering pump
Don't want to steal the thread but would like to ask a question regarding type II pump and rack and pinion. Latech, in your knowledge of power steering is the type II and rack compatible?
Old 10-22-2018, 06:45 PM
We changed out the pump this summer on an old chrysler and used the walmart power steering fluid. Foamed up like crazy. Reading the label would have prevented the issue because it clearly states for topping off only, not for a complete refill. Flushing three quarts of the proper spec fluid and then a resrvoir refill cured the foaming/aeration. There is no restrictor on our system so I'll hope removing it in your system takes care of the issues you are having.
The Following User Says Thank You to seven up For This Useful Post:
64nailhead (10-22-2018)
Old 10-22-2018, 07:59 PM
64nailhead's Avatar
No worries. I'll offer my guesses to your question based on what I read on the interwebs - yes, a type 2 pump will work with a rack. I intend to swap to a rack at some point when we expect this tank to turn at speed lol.
seven up,
I have to admit that our giddy up worked best when the entire setup was from the junkyard - gear, pump, steering shaft and reservoir. The pump front seal started seeping and I thought that would be a good time to get rid of the Saab plastic reservoir. It hasn't been right since. Made it through the summer, so can't complain too much.
After doing a little 'anal azation', this chinesium $30 reservoir I bought has a 3/8" hose going through an 1/8"npt fitting. Perhaps it's time to bust out the box of used fittings and tap it to a 3/8"npt.
Old 10-23-2018, 07:33 AM
Type II Pump with Rack and Pinion
39 Master, I posted a similar question a year ago titled Power Steering Pump Locations. 64 Nailhead was key in providing the information. I used a Type II pump with an 88 Thunderbird Rack (Not Mustang II) in order to match pressure levels and not use a restrictor in the system. Works excellent. Search for that posting thread for additional information.
The Following User Says Thank You to zooma For This Useful Post:
64nailhead (10-23-2018)
Old 10-25-2018, 07:47 PM
64nailhead's Avatar
Resolved!!!
Whether it was the return fitting diameter being too small or the fluid it turns the way it did prior to changing the reservoir and pump and adding in the restrictor. I feel kind of stupid for adding the restrictor as my thought process was 100% backwards - I need either more flow or less restricted return flow.
All's well that ends well. Thanks for the input.
Old 10-26-2018, 06:11 AM
Bob37pont's Avatar
Curmudgeon at Large
I have the same setup. Original builder used a real 74 MII rack with a type 2 pump. I recently replaced the rack with the 88 T-bird unit from Speedway. It works great with the type 2 pump. Biggest hassle for me was figuring out the new plumbing, the fittings on the new rack are different than the MII rack.
power steering issue sportcoupe Suspension - Brakes - Steering 3 04-09-2012 08:45 PM
power steering pump issue truckboy61 Suspension - Brakes - Steering 17 08-25-2011 05:57 PM
power steering pump issue truckboy61 Engine 3 07-01-2011 10:35 PM
power steering pump issue truckboy61 Engine 3 06-01-2011 02:34 AM
Power! -- No power? -- Power!!!! No Power???! Fragzem Engine 10 05-16-2005 02:30 PM
