Powering Bead Roller - What Works? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2016, 10:24 AM
I want to power my Princess Auto bead roller. Like most of you, I like to do things as cheap as possible, and use what I have if I can. I've seen lot's of threads suggesting cheap solutions, but what actually works. So far I've seen John Longs garage opener, a 1/2 drill, and a cheap winch, that all seem to work fine. What about 12 volt window motors, and wiper motors? I've seen these suggested several times, but is there anyone who's actually seen them work, and work well?
Old 01-05-2016, 11:47 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
There a lots of Youtube Videos on how to motorize the Harbor Freight Bead Roller-Google is your friend here, but here are a few:
https://youtu.be/-M37lnkkvSw
https://youtu.be/3GSD-SalaNU
https://youtu.be/2a4CO2yeR6w
Lots of ways to skin a Cat-
Old 01-05-2016, 06:57 PM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
metal meet >?
I used a 12 V Harbor Freight winch and instructions from Metalmeet. The winch is reversible and has a handle to pull out to disconnect the power and run by hand. Norther tool has a 120 V winch with the yellow button control simiolat to eth HF one. Tread mill motors and controllors acan also be used. Youtube on modifying the electronics. And if you search here on hotrodders you will find more info. Check out jere kilpatric.s mod for a qujick release and adjustable shafts
https://www.youtube.com/watch?v=Ra2-A-IuT-Q
Old 01-05-2016, 07:12 PM
hp246's Avatar
Metalmeet and some of the other metal working forums have some pretty good directions. Some of those youtube videos are down right scary. Especially the one with the big chain and gears. Great for getting a sleeve caught in. And the one where you can only hold the work piece with one hand? Would probably make for some really accurate bead work. The one with the foot pedal look the best, and is pretty consistent with some of the production models I've used.
Converting bead roller to power John long Garage - Tools 76 12-18-2019 10:15 PM
Improving your HF bead roller deadbodyman Garage - Tools 36 04-11-2014 09:19 AM
bead roller size freeskier Garage - Tools 0 02-22-2011 07:15 PM
Using a bead roller...backwards... AngliaBob Body - Exterior 2 02-20-2005 08:19 PM
Using a bead roller backwards??? AngliaBob Body - Exterior 0 02-18-2005 06:21 PM
