Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Powertrax Locker: 1/4 mile time increase?
Old 04-12-2004, 07:23 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
If there is a way you could have someone videotape your run from the line to the 60 foot mark so you could review tire slippage this might be a starting point to see what and how much slippage you are starting with.
I am guessing you are already doing the tire pressure adjustments and whatever else you can to get things hooked up right for your times.
The lock-right will just lessen chances of slippage, and MAY increase your ET's, but it wouldn't likely be a whole lot.
