Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - PPG epoxy failing
Old 06-17-2016, 05:29 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Last wiki edit: Stripping paint
Wiki Edits: 11
Now I can't make this clear enough, I am not saying it's impossible. I am also not saying that the product could be way to temperamental where a tiny little thing can make it fail that another product wouldn't be affected by the same "mistake."
That being said, as a painter for 20 years at the time I became a paint rep which I did for 4 years in the late ninties, I never saw a product fail like that where there was anything wrong with the product, it was the application.
Now I say that because on a regular basis I was attending to failures where the customer blamed it on the product. It is so common it's crazy to hear terms like "bad batch" and stuff like that. I researched these failures over and over and over, saw everything you can think of and a few that would blow you away they were so damn stupid.
So if you really want to FIX the problem and not simply throw blame, study what you did, study the substrate , study the temp solvent and or catylist used. Study the application, the amount of coats of the primer and the substrate, how much overlap, ANYTHING that can affect the solvent that stays in the film, solvent entrapment is without a doubt the number 1 reason for failure, hands down.
Just some ideas as I know nothing about those products in particular.
True enough...But still, Dp epoxy is just plain junk. get rid of it. Just like some cheap primers shrink, its just how they are, stop using them.
The Following User Says Thank You to deadbodyman For This Useful Post:
Rustyfender (06-21-2016)
