Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - PPG epoxy failing
  #22 (permalink)
Old 06-25-2016, 09:58 PM
carolinacustoms's Avatar
carolinacustoms carolinacustoms is offline
Automotive Extraordinaire
If you are concerned about compatibility, I use SPI epoxy and urethane primers, as well as SPI universal clear coat, all with PPG base coats and have not had any issues with any of the above combinations. I do recommend the SPI base coats if you have the chance to use one of their colors. For a general process, we 80 grit bare metal with a DA and then clean with waterborne then solvent based W&G remover and apply epoxy.
Kelly
The Following User Says Thank You to carolinacustoms For This Useful Post:
AutoGear (06-28-2016)
