Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Primer Surfacer Help for Corvette
Old 02-04-2005, 11:09 PM
AC/DC AC/DC is offline
I still don't think you should put lacquer over a activated urethane. Why would you use a good 2k system(if that's what you primer is) and then put lacquer on it? Urethane reducers will soak into a urethane primer, wait until the lacquer reducer gets in it.
