Primer Surfacer Help for Corvette - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 02-21-2005, 02:21 PM
The biggest thing reguarding polyester primers is temperature, the surface of your part should be about 70 degrees as well as the air in the room. If the temperatures fall lower than this the curing will be delayed by a great amount. And make sure the primer is well stirred before loading your cup. Featherfill 2G is good stuff IMO. No shrinkage, good sanding, excellent adhesion, and it can be used over any cured 2K component along with etching primers.
  #47 (permalink)
Old 05-17-2007, 04:41 PM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
I used DP epoxy primer on my 69 Vette, no problems after 5 yr.s
  #48 (permalink)
Old 05-19-2007, 02:59 PM
Originally Posted by roger1
For my 69 Corvette, I am considering using either Evercoat's Finish Sand Polyester Primer or Evercoat Uro-Fill Urethane Primer.
Could anyone give me some recommendations which would be better to use?
I completely stripped the car and it is down to the bare fiberglass. However, I used chemical stripper designed for fiberglass and did not damage it. I will be using Acrylic Lacquer for the color.
Any advice will be appreciated.
I would use urethane primer it is a better primer than polyester primer. But one good thing you should know LACQUER is not a good paint use urethane all the way around and yes Im certified for paint by martin senour.
  #49 (permalink)
Old 06-29-2007, 03:18 PM
O.k. what is this crap? Post #49 and #50 are links to porn sites!
gcrmcc
  #50 (permalink)
Old 07-27-2007, 09:40 AM
302 Z28's Avatar
Pijanebrazylijki and Luvoeve have been banned.
Vince
  #51 (permalink)
Old 07-27-2007, 09:44 AM
Good, Thank you!!!
gcrmcc
  #52 (permalink)
Old 07-27-2007, 09:49 AM
302 Z28's Avatar
[QUOTE=gcrmcc]
Good, Thank you!!!
gcrmcc
This forum is getting nailed for some reason. Several of the bogus usernames have the same IP address but others are different. I am not a moderator in this forum so I cannot edit or delete a post.
Vince
  #53 (permalink)
Old 07-27-2007, 03:08 PM
Wiki Edits: 49
Most of the spam bot post have come from one IP address and Jon has banned that IP. Obviously we have a new spam bot that has found this thread so we'll have to deal with that one as well.
The big thing to remember here is that these posts aren't being made by an individual. It's an automated process that looks for certain key words and then automatically registers and posts the porn links. Jon has to be careful when banning an IP address because it could effect legitimate members as well. Just keep reporting these posts when they happen and when we have enough information to assure that no legitimate member's IP is associated with the offending one the spam bot's IP will be banned.
  #54 (permalink)
Old 07-27-2007, 03:22 PM
I'm glad you all have it under control and hopefully all figured out.
thank you!!
gcrmcc
