PROBLEM with Monroe shocks - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2018, 07:49 PM
bullheimer's Avatar
NEVER use credit cards!
Ordered them from summit for the front of my 62 buick and they dont even come close to fitting. under the description listed for the part at rock auto, they are a dead on match, however the part i got from them as well as the part i got from Gabriel are the same, and are MUCH SMALLER in every dimention and will never fit.. i have a question into summit about this, if they can open the box first before they send it. btw summit's phone customer service and tech are now g a half an hour on the phone waiting for them to answer. HOWEVER, they are being AWESOME once i went from tech back to sales, and they are going to open the box up and measure the T bar before they send me two new ones. hopefully they fit.
specs: Lower Mounting Description Cross Pin Mount - Open Ended, 3/8" Hole ID (Both Ends) X 3.3/16" Pin Length (Hole Center to Center)
actual size, holes about 5/16s, total length of T bar 3 inches, i'll show a pic
i have sent them back already, no problems with that. and currently back on the blower with them waiting to see if they can open these up. by the time that happens, my edit option will have times out. so just assume i'll be back with a second post on this. keep in mind monroe closed three hours ago, and it is after 6pm pst on a friday. they are back on the phone telling me they are going to look for this. so im happy as i can get. i got to say that other than waiting forever to get thru to anybody, eventually you do and summit did great. hopefully i'll be getting a phone call back when they find them and i actually hear my phone ring. ps the monre oe pn i want is 5759
Name:	BUICK SHOCKS.jpg
Old 07-28-2018, 06:47 AM
Bob37pont's Avatar
Curmudgeon at Large
I had to replace the unknown brand air shocks on my '37.
I measures what I had and the mounting configuration and went on the Monroe site.
Under 'tech specs' you can see a pic that shows mounting configuration and will give you all the measurements. I searched all the air shock pics until I found the matching configuration and measurements!
You can put in your vehicle info to find measurements and see if the # you have is correct for your car.
Or enter the part # to get the fitment application and measurements.
Old 07-28-2018, 08:19 AM
Old(s) Fart
Last wiki edit: Wheelbase database
I went through this same problem with KYB shocks for the front of my 67 Delta 88. Bottom line is that apparently ALL the shock manufacturers now incorrectly sell the smaller A-body shocks as also fitting the B/C-body cars. The trick is to check the applications. If the shock claimed to fit your full size is also shown as fitting an A-body, it will not work. I sent the following photos to KYB explaining the problem. They said that they'd look into it. Fortunately I did not hold my breath. There just aren't enough of these full size cars on the road any more for the shock manufacturers to care.
Old 07-28-2018, 11:15 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You can call the tech line at QA-1 as I have found those guys to be helpful in one of these predicaments.
Sam
Old 07-28-2018, 06:41 PM
Old(s) Fart
While you should't HAVE to replace the cross bar pins to make a shock work if the manufacturer says they fit, you can get these cross bar pins for $4 apiece from Jegs with 3.14" hole spacing.
https://www.jegs.com/i/Skyjacker/825/BP18/10002/-1
The Following 2 Users Say Thank You to joe_padavano For This Useful Post:
Bob37pont (07-29-2018), kbuhagiar (08-11-2018)
Old 08-10-2018, 05:21 PM
bullheimer's Avatar
hey thanks for that.
Summits rep has been awesome. she called monroe and sent them the picture i sent her and said they will drop ship me the right ones right from monroe.
here is the email i just got from her:
"Sam,
Was able to get back in touch with the manufacturer, they have plenty shocks available to ship from their Arkansas warehouse. I got in touch with the gentleman I previously spoke to about the quality check of the shocks they have available. He reassured me that the shocks you received from us must have been from older stock produced in April, back when they were made with the wrong cross-pins."
so Bob, you found Air Shocks that fit your rear? i couldn't find anything made specifically for my car. i think my rears are both eye holes top and bottom. what kind of shocks did you end up with for your rear. monroe what p/n?
that said, it doesnt explain how Gabriels were wrong also, and yours too Joe. when at least monroe and gabriel are supposed to manufacture their own product lines.... hmmmm!
Old 08-10-2018, 06:44 PM
Old(s) Fart
"Sam,
Don't hold your breath. So long as they show the same part number fitting both an A-body and a B-body, the shock will be wrong. Those two car lines do NOT take the same shock, thus the problem. I'm curious to hear how this turns out, but I'm not optimistic.
Old 08-11-2018, 07:26 AM
Bob37pont's Avatar
Curmudgeon at Large
I found Monro Max Air MA750 matched what was on the car, both visually & by measurement. Fits 1979-1989 Dodge Diplomat. Mounts with an eye on top & a straight rod on the bottom, looks like it is upside down! I have no idea what bottom plate/bracket was used when the rear was swapped into the car.
Old 08-11-2018, 08:08 PM
PHWOARchild's Avatar
Monroe should have a catalog online with dimensions, you can match the old ones up feature by feature. I don't think they have as many shocks out there as they used to have. Or something went amiss if they consolidated the product line at some point.
Old 08-17-2018, 05:33 PM
bullheimer's Avatar
so YEA!!!! I GOT MY NEW SHOCKS TODAY AND THEY ACTUALLY ARE THE RIGHT SIZE!!!
summit got Monroe to get with the plan and make the part to fit the cut sheet, and sure enough, i matched them up to the old ones and they are exactly as they are supposed to be.
bob, i'll have to wait till i get more bucks up to try to go back onto their site and match up some air shocks to my bu-yick! would be nice to get it up in back some but truth, i'd LOVE to radius the fender wells instead. but i'm still looking for ANY kind of wheel that will fit these stinkin axles!! if anybody knows looking at this post thru the years, go ahead and clue me in cause it will no doubt be years till i can buy them.
so.... shock problem solved
Ride height with Load-Adjusting Monroe shocks wave1957 Suspension - Brakes - Steering 3 03-04-2014 03:04 PM
Hello from Monroe, CT Barsteel Introduce Yourself 1 12-10-2012 09:17 AM
Air Shocks/Gas Shocks? 72Skylark Suspension - Brakes - Steering 2 01-26-2006 07:57 PM
Monroe, Ohio Brian Morency Hotrodders' Lounge 2 01-03-2005 06:15 PM
Anyone use Monroe Sensa-Trac rear shocks? KeithB123 Engine 2 01-17-2004 09:47 PM
