Problems with rolling up passenger window on my 47 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2019, 09:49 PM
47 Ford Coupe Delux's Avatar
A while ago I started having issues rolling up the passenger window. The hand crank would seem to be skipping a tooth when rolling up the window and it wouldn't close all the way up. Today as I was trying to close it I noticed that the front edge of the window got chewed up and cracked. When I removed the door panel to take a look I couldn't really see much or even gain access to the window mechanism. How do even access that?
Also, what are my options for replacing the cracked window? (the roof of my car is shopped a few inches)
Thanks for your suggestions
Old 09-23-2019, 05:18 AM
FASTFORD's Avatar
when you get the window out, any decent glass shop can copy it.
I`m not familiar with the workings of a 47 window & door assembly so I cant help with that.....
The Following User Says Thank You to FASTFORD For This Useful Post:
47 Ford Coupe Delux (09-25-2019)
Old 09-25-2019, 03:52 PM
I took a closer look and noticed that the regulator gear has some broken teeth. That would explain why the window doesn't go all the way up.
Old 09-25-2019, 05:37 PM
FASTFORD's Avatar
is this what you need ?
https://www.macsautoparts.com/ford_m...er-442054.html
Old 09-25-2019, 05:42 PM
39 master's Avatar
Not easy working inside the door but they got it in so it will come out. Now you have a decision to make, buy a new regulator or go to power windows.
Old 09-25-2019, 09:52 PM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
If you do go power windows, be prepared to spend some time making them work correctly.
Also plan to change the felts, make a window out of Plywood 1/4''
Having a copy of the glass window in plywood, will allow you to trim and size it for the window track. Shooting for a smooth operation, very important. That then becomes a working pattern, then get the glass cut.
Do not buy pre-cut glass, have it made. Many glass companies, that do glass bathroom showers will also do auto glass.
Another thing to know, the wiring harness & switches
cost as much as the regulators. Not a cheap upgrade
Pep
Old 09-25-2019, 11:07 PM
Originally Posted by FASTFORD View Post
That link doesn't show any specific part.
Old 09-25-2019, 11:22 PM
I don't want power windows. I need a mechanical regulator.
Old 09-26-2019, 05:00 AM
FASTFORD's Avatar
I dont know why that link does not show the part.....it works for me ....
go to the site & search for part# 32-68151-1
it is the window regulator small gear.
47 Ford Coupe Delux (10-01-2019)
Old 09-26-2019, 07:07 AM
rip-tide's Avatar
Here ....................... V
But I'm thinking the missing teeth are on the part that lifts the glass. With the way the problem is described.
He might be in for a real adventure finding that
Pep
Old 10-01-2019, 12:31 AM
Pep
That's not the part I was referring to. If I remember correctly the part that has the teeth looks like a saw. Thanks for the link anyways
